Results 1 to 10 of 11
Thread: footplate now in
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Default footplate now in
    quick pic from my phone of my GM pedal set from an astra paired with a ditchp footplate
    YES IT STILL NEEDS A CLEAN!!
    Sunny Dartmoor
    Looks great m8.........
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    look's the biz that, are the astra pedal's a direct fit or did you have to modify them ???
    Midlands Mod Shop - NFFC.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Cracking adition to the pedals
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    Looks good
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    spot on mate
    Irmscher Insignia CDTI 130
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Look good, but are they the original rubbers we can see under the new brake and clutch pedals..?
    Liverpool & Norfolk
    thanks for the comments
    Quote Originally Posted by ditchp View Post
    only the accelerator is direct fit, just clips on no problem
    this will also answer ditchp's question......
    no what you can see is not the original rubbers, its the wrap around rubber of the new pedal - on top of the actual pedal, if that makes sense. Vec C brake & clutch pedals are bigger than the Astra H/Zafira B/Tigra (models these pedals were intended for)
    so the only way to fit them 2 was to glue them onto the actual pedals - i didnt expect this method to last at all but it has. so the new rubber has simply been glued onto the pedal & has worked fine
    ill keep it this way til they come off, then possibly try removing the rubber & stick metal on metal
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by m111kan View Post
    Very nice ... I wonder where the footplate idea was from...?
    Trim : Get a
    Quote Originally Posted by Ian T View Post
  1. Replies: 8
    Last Post: 19th March 2010, 00:47
  2. irmscher pedals now fitted! + footplate
    By mitch in forum Quick Photo Album
    Last Post: 22nd February 2009, 23:53
