Thread: Cruise Control
    Apr 2006
    Ash, Nr Aldershot
    Default Cruise Control
    Hi all
    Just been for a little run to the Watercress line in Hampshire to take some piccys of Tornado, on the way back tried to engage the cruise control and nothing!. Must admit i haven't used it for a while, October at least as the wife normally drives the car and she won't use it. Read a thread about cleaning the contacts in the stalk so might try that first. Any other ideas? can't find any reference to it in the Haynes Manual.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    YES!, drive the car making sure you have used the brakes, tug outwards on the stalk Whilst pressing the set button at the SAME time, if it works, here you go looked back and found the link.
    http://www.vectra-c.com/forum/showthread.php?t=100146
    Regular Member david.aka.judas's Avatar
    Suffolk
    lift the clutch up with your foot, it may be the clutch return spring.
    I need to check mine, the C/c turned itself off twice on the way to ipswich.
    it may need a new spring.
    Apr 2006
    Ash, Nr Aldershot
    Thanks a lot, i will try both of these suggestions
    Aug 2009
    Bristol & Stockton on Tees
    The cruise control is somes reluctant to turn on with my 08 plate ELITE - every time so far has been the brake pedal switch. The problem has always cleared after dabbing the brake pedal.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Pete Elite View Post
    Thats not a problem, its a safety feature to check the switch on the brake.
  1. Cruise Control.
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 10th January 2011, 21:24
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
