Thread: Expansion tank cap!
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Unhappy Expansion tank cap!
    Bit of a problem with the expansion tank cap on my Dad's Vec C....the Yellow top/cover has seperated from the body of the cap, with the body still screwed into the tank and i cant find any way at all of getting it out considering how ruddy tight they are anyway
    I tried evo stick last night in the hope that it would bond the cap back to the main body and enable it to screw out, but no...
    anyone else had this and how did you get it sorted?
    Full Member Big Sig's Avatar
    New tank and cap?
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    New tank and cap?
    Hoping we wouldnt have to go down that route, tank was only replaced last year as it was split....might be the only option though
    Mileage : 000
    I belive gtr1000 had the same problem. I forget how he got his "back to normal".
    When you get your new cap. I suggest a squirt of silicone spray on the "o" ring, as that is what seems to seize in the cap.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by ed taylor View Post
    Here's my original thread http://www.vectra-c.com/forum/showth...hlight=coolant.
    I did post up somewhere that I'd sorted it - two flat blade screwdrivers and mole grips to pull the stuck bit. I did it on my own but would be easier with extra hands.
    Then you'll need a new cap, don't bother trying to repair the old one.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Hmm, cheers...hopefully we can get it out.....anyone know where i can get a new cap from, other than Vauxhall?
    (Or if someone on here is willing to get me one on tradeclub, id be very grateful)
    Nov 2009
    Luton
    had this problem a while back, drove car as normal and when the engine was still hot a got some pliers on it and pulled hard! and pop out it came, hope this helps
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Aye thanks Dave ....ordered a new cap anyway, so when it arrives i'll give it a go...didnt want to do owt before the new one comes
    *Although i didnt think doing it when its hot could be good due to the pressure of the system?
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    New cap arrived yesterday....old bit removed with screwdrivers and pair of grips. (and some added swearing for good measure)
    Put a smear of Vaseline on the O rings on the new one, and it goes in and out very easily (oooh err)...
    Pretty sure the Head Gasket has gone now though!!
    Regular Member muffking's Avatar
    Same problem on mine, I think the heat makes them brittle. I've drilled the sides in mine to remove with a thin screwdriver, but does anyone know how much a new bottle it?
  1. expansion tank
    By Swedge in forum Engine & Drivetrain
    Last Post: 1st August 2012, 18:21
  2. expansion tank cap broken
    By mrk in forum Troubleshooting
    Last Post: 24th November 2011, 19:53
  3. Where to get a new expansion tank
    By Morephun in forum Engine & Drivetrain
    Last Post: 19th December 2010, 19:53
  4. expansion tank
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 21:25
  5. expansion tank
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 17:41
broken expansion tank cap
vectra c expansion tank cap
vauxhall corsa c coolant cap tightness
vauxhall signum expansion tank cap
2006 vauxhall vectra 1.8 sri coolant cap broke
how dose a exspansion tank cap works on vauxhall corsa
pictures of how exspansion cap works on vauxhall corsa
vauxhall insignia coolant expansion tank cap
vectra c 3.2 v6 exspantion tank tub
how to remove a broken header tank cap on 2006 vauxhall zafira b
what is the middle part of the vauxhall vectra expansion tank cap
corsa d expansion tank cap
vauxhall insignia coolant cap fell apart
corsa d expansion tank cap broken
vectra c expansion
vauxhall insignia expansion tank cap broken and stuck in tank
vectra c header tank
where is expansion tank in vauxhall vectra
