Results 1 to 10 of 19
Thread: Vectra C check engine HELP!
    Regular Member claudiu666's Avatar
    Bristol
    Default Vectra C check engine HELP!
    Hello everyone
    I just bought a Vectra C 2003 , 1.8 petrol( i don't know where to look to see what is the code of the engine) .
    I was very happy with my car the first 2 days but yesterday I saw that check engine is on and when I start the car it loses engine idle but not very badly then when it warms up it's okay. I've read the codes with the break and acceleration method and it gives me :
    -P0170 Fuel Trim Malfunction (Bank 1)
    -P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1
    -P0110 Intake Air Temperature Circuit Malfunction
    -P0335 Crankshaft Position Sensor A Circuit Malfunction
    I am very sad because of this problems. Can someone tell me what is the reason? Is it the Maf sensor ? Lamda sensor or the egr? Or is something worst then this
    Please help me !
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    -P0170 Fuel Trim Malfunction (Bank 1) - fuel mixture is weak/rich on bank 1 (before the catalyst) this is normally caused by an intake air leak or sensor fault such as throttle position sensor or air mass meter,check exhaust for any leaks too,or it could be lambada sensor
    -P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1 ) Basically means the oxygen sensor is inactive,could be related to above sensor
    -P0110 Intake Air Temperature Circuit Malfunction - MAF sensor ? check all plugs going to MAF sensor
    -P0335 Crankshaft Position Sensor A Circuit Malfunction - Crankshaft sensor
    I would get codes reset then read them again in case some are old,it could be all intake codes are related to the MAF sensor but i would wait for another opinion
    Irmscher Insignia CDTI 130
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i would do as big mac said clear the codes (could be old), then go from there, see what codes reapear!.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Just in case you need it,not sure if this is the complete sensor AIRFLOW METER (AIR CLEANER) (WITH MASS AIR FLOW SENSOR) (FOR 1.8 ENGINE) £22.16
    Bristol
    How do I reset them by taking out the batery? Next week should my scanner arrive U480 just purchased from ebay hope that could be more helpful . The problem is that it hunt on idle when I start it and also when I keep a constantly Rpm . For example with the cruise on at 2000 rpm I fell like it's breaking than it accelerate again.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    To me its all MAF related but cant be 100% sure go to a scrappy and try and get sensor or buy that one above and try it.
    Like i say its a hard one to solve as it could be just a leaking exhaust or a sensor so its a process of elimination i'm afraid
    Bristol
    Thank you!
    I forgot to mention that I hear air getting out somewhere under the battery . is it normal? I cant see where it is .
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Check for air leaks then this might be your problem
    Bristol
    I am just hopping that it's only the sensors or maybe the exhaust . Also i could't find how to clean the egr for 1.8 in the "How 2 " . Can you also tell me where to look to see the engine code . Couldn't find that also . I am just start learning cause it's my first vauxhall
    Bristol
    I have looked all day after that air leak that I am hearing near or under the battery. Any ideas where should I look ? what pipes are there in that area? Today for 10miles the check engine turned off and the car was running great but then get back. uff
  1. Colour And Engine Check
    By PORKBALLS29 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2010, 15:26
  2. CDTI Check engine light
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 20th May 2010, 18:17
  3. Vectra C 3.2 - Engine Check Light and Traction Control
    By bigmac22 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 08:13
  4. can i check my new engine number
    By garvey in forum Engine & Drivetrain
    Last Post: 29th November 2008, 16:32
  5. check this out ... engine mod
    By rob 2.2dti in forum The 'Off Topic' room
    Last Post: 22nd June 2008, 01:01
check engine opel vectra c
opel vectra c check engine
check engine vectra c
