Thread: diesel noob needs advice no boost under 2k
    Aldermaston (Berks)
    Default diesel noob needs advice no boost under 2k
    Hi everyone, got my new car, the 2.2 sri & i love it. However it has some small issue's which i need guidance with.
    1st 1 is there is no power below 2000 rpm, over 2000 rpm it goes ok but i thought it would be a little quicker than it actually is.
    2nd problem is the age old mpg question, i'm no rally driver and the car is doing about 35-37 mpg on runs to and from work about a 10 mile round trip.
    It takes it time warming up, this is with a new stat too, apart from a good service does this sound like the e.g.r i keep reading about on here.
    Thanks all.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the egr is normaly a diesel fault. the trouble with economey is 5 miles each way isnt realy that far and if the heater is being used on red hot it will strugle to get warm
    Aldermaston (Berks)
    Ok the heater side of things is understandable & short journeys, any idea's with the boosting issue, i should point out it did have new boost sensor from the stealers before i bought it. Oh by the way lol i should have said it is a diesel.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes just relised it might be the egr a bit blocked but have a look at your vacume pipe and mostly th rubber joins as they split and cause alot of probs
    Aldermaston (Berks)
    im on the case now
    Quote Originally Posted by mr.c72 View Post
    That's quite good really, my previous Vectra B 2.0 used to do between 28 and 32 mpg
    The Vectra C is slightly heavier with a larger footprint, so although fuel economy may be better, tyre and brake wear is going to be higher
    Aldermaston (Berks)
    right all of me vac pipes and elbows on the vac pipes are in tip top condition, all turbo boost hoses look to be fairly new.
    I just whipped of the e.g.r valve and it looks like the inside of a sooty chimney, cant tell if its working or not though, could this be related to the less than average performance of my car if it was the e.g.r at fault?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Yes! the egr will most certainly affect performance, follow the How 2 for cleaning the 2.2dti egr,
    Aldermaston (Berks)
    Ok thanks for the advice guys.
  1. 1.9 diesel/150 bhp - EGR advice please
    By paulf2012 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 23:52
  2. 10k diesel boost help
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2011, 09:30
  3. 10K Boost Diesel De-coke
    Last Post: 23rd July 2010, 22:56
  4. 10K Boost Diesel Decoke-I want to hear from you IF you've used it!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 15th December 2009, 22:40
  5. Advice needed on boost controler and gauge.
    By shippers in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2008, 00:42
