Results 1 to 10 of 18
Thread: Heater on 4 and wet n/s carpet
    Lincs
    Default Heater on 4 and wet n/s carpet
    When i bought the Vectra, the dealer told me the carpet was wet and the drain hole had now been cleared. However, the car mists up, the fan only works on 4 and the recirculation button doesn't light up or make any noise when i press it.
    I've had a read about on here and i'm not that techy, but would a new heater resistor and pollen filter cure this? Not sure on recirculation button though
    Thanks in advance.
    Paul
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep new resistor needed mate, out of interest what setting were you trying to use the recirc button on as iirc it only works on certain settings
    Lincs
    Hmmm, i don't remember, i'll take note and post back.
    Many thanks
    Lincs
    Quote Originally Posted by pauldellboy View Post
    Many thanks
    That now is ok, the recirc didn't work on the screen setting, thanks for the heads up.
    However, all side windows misted up like crazy tonight when i had passengers inIs it just because my carpet is wet or do you think the pollen filter needs looking at?
    Cheers again.
    Full Member Big Sig's Avatar
    Check the filter but you need to dry the carpet out as well. As already said you also need a new resistor pack for the heater fan to work correctly.
    Lincs
    Cheers.
    I've just checked the filter, it's dry but mucky and full of bits.
    I keep towelling the carpet and leaving the doors open when i can. Is there any better way of drying it out?
    I intend to buy a new resistor pack off e-bay rather than a repair to mine. What are peoples thoughts on a repaired resistor?
    Thanks.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    leave your a/c on for a week to suck the moisture from the carpet and if it isn't raining the windows slightly open if its sunny to let the damp out
    East Midlands
    Cheers.
    Thanks.
    There is a better way of drying your carpet paul,if you have access to a dehumidifier,push the front seats back as far as they go,and stand the dehum in your car and it will dry like lightning..hope this helps.
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    79p fix works a treat.
    PS you cleaned the drain away to stop this happening again?
    Lincs
    Thanks for all advise. Yes, drain is clear, but i'll get a new pollen filter. I don't have a dehumidifier, but i'll leave a/c on and at the moment it's sunny so doors are open.
    Cheers everyone.
  1. What are these on the carpet?
    By weidass in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 12:15
  2. Carpet
    By vec-cal in forum Detailing and Car Care Discussion
    Last Post: 18th June 2011, 15:47
  3. car carpet
    By neverlandandy in forum General Chat
    Last Post: 25th March 2009, 13:41
  4. carpet
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 17:51
  5. Carpet mat set Vec C
    By blue estate in forum Parts for sale
    Last Post: 19th March 2008, 22:31
