Results 1 to 10 of 18
Thread: what tyre pressure??????
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    Default what tyre pressure??????
    Hi chaps i have 19" snowies and i was just wondering what is the correct tyre pressure my mate said put 38 psi in i did and they looked like they where bursting off the rim ...but the other day my other mate read on the tyre they should be 50 odd psi eehhhh can this be right? at the moment i have 33 psi in i have never had low profile tyres before but i feel i am allways putting air in them....
    thanks guys
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    Search button is your friend
    Regular Member vxr-i-wish's Avatar
    Nov 2009
    Quarry Bank, W.mids
    from what ive seen tyre pressures should be approx 2x the rim diameter. Mine are at bout 40-42psi. hth
    West
    Double your rim size as a general rule... 38 is fine
    Jan 2010
    northumberland
    Quote Originally Posted by vxr-i-wish View Post
    really 40 ish mine looks the same as yours ehhh when i put 38 in the tyre was over lapping the alloy i thought with low profile tyres the alloy sits flush with the tyre
    Regular Member colalowe's Avatar
    in the North
    The manual states for the the 1.9CDTi 19inch wheels
    Loads up to 3 people front 39psi rear 35
    Full loads front 41psi rear 48psi
    hope this helps
    Jan 2010
    northumberland
    so you think say 38psi..... should the tyre be over the allow rim? becouse thats what happens when i put that amount in if you look down the alloy the tyre sticks over the rim
    in the North
    Some low profile tyres have a thick rim that is designed to stick out from the alloy to slightly protect it from curbs etc, it could just be that.
    Jan 2010
    northumberland
    Quote Originally Posted by colalowe View Post
    possibly but when i ran my finger around the edge it was kinda uneven slightly bulging in more places than some.... my drivers side tyre has uneven wear the outer rim is alot lower than it is in the middle i think its 1m so i am getting it changed this week do you think becouse i have not been putting enought air in and thats the side i sit its putting more w8t on the tyre cousing it to wear unevenly
    Full Member Big Sig's Avatar
    Quite possibly, low pressure normally causes the outter edges to wear first.
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. Tyre pressure
    By Ralphwells1967 in forum Handling & Braking
    Last Post: 8th May 2010, 19:26
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
