Results 1 to 10 of 15
Thread: Full canbus nokia telemute ?
    Ireland
    Default Full canbus nokia telemute ?
    Can anyone recommend a decent plug and play option for a nokia CK kit and facelift with Cd30 ?
    I'll probably switch to a Cd70 at some point too, will that make any difference ?
    I'm using an Elan Inellimute at the minute with a nokia CK-20W so I can stream music from my iPhone straight through the head unit but the Elan box is very tempremental and functionallity isn't great (it mutes the stereo if I receive a text or unlock my phone, even with the alert and keylock sounds off then takes 10s to unmute it. It also seems to loose it's settings now and again, meaning it has to be removed and re-programmed to the car. Getting fed up of puling the glovebox out now.)
    I've done a search but can only find info on parrot kits.
    Camberley
    I've heard of plug behind the glovebox for use with hands free kits. I've also seen a lead for the nokis ck that plugs straight in.... But I can't find the actual plug behind the glovebox. Can any one help?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    mine was striped in
    when removed the glovebox, it was in the "hole" to the radio.. was difficult to find. But dont think it is on all cars..
    Mar 2007
    North East
    The VDO plug is on pre facelift (half can) cars only. It's on the right when you take the glove box out, quite possibly taped up.
    Ireland
    Yep, as rockh says its not there on facelift cars. I`ve ordered an autoleads 06-125b, hopefully this will work bettter than the Elan intellimute I have.
    Preston Area
    half can ??? my vdo connector was there connected to my cd70!
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Connections are very simple anyway. Typical Nokia CK units connections are
    Nokia CK unit Yellow wire to pin 11 of full can radio - telemute function
    Nokia CK unit Blue to ignition live (Cig lighter on full can cars)
    Nokia CK unit Red to permanent live - pin 15 of full can head unit
    Nokia CK unit black to any good chassis point, grounding screw
    Nokia CK unit speaker output pair to pins 34 (signal +) and 40 (signal -) of full can head unit
    Half can Radios...
    Half can wiring varies,
    But the yellow goes to mute wire on pin 34 (NCDC2013)
    and the speaker pair go to pin 35 (signal +) and 36 (Signal -)
    although I have alsoseen it go to pins 31. 32 and 33
    Wires are on head-unit regarless of pin number are: -
    Vauxhall radio colours..
    Black (mute)
    Blue (speaker +)
    and brown (speaker -).
    Ireland
    Thanks Robsey, I`m sure that`ll be usefull for anyone doing a search in the future.
    Autoleads part No is 06-122b not 125b as I said above. Plug and play and just the Blue wire to scotch lock onto the cig lighter for a switched live.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It would be better to solder the wire and heat shrink sleeve it if you can...
    I've never been a fan of the Scotch Lock thing.
    Skotch-Loc's are okay for cheap and chearful temp mods, but with such sensitive electronics in the Vectra, and assuming that you will be having this fitted for a few years...I would definately recommend soldering etc.
    Ireland
    I probably will at some point.
    Anyone know what the extra connector is for taped to the cig lighter wires ??
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. For Sale: Full Canbus GID
    By MURDO in forum Parts for sale
    Last Post: 21st May 2012, 13:30
  4. full canbus help please
    By chowwie in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 00:50
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
