Results 1 to 10 of 14
Thread: cannot get air lock out of Diesel fuel lines
    Sunerland
    confused cannot get air lock out of Diesel fuel lines
    Hi guys,
    CAR .... 2ltr DTI vectra C 53 plate
    I replaced my fuel filter today and now the car wont start. I know i have an air lock .
    Checked manual and it states i need a ( KM-948 ) i have done everything to the best of my ability but to no avail.
    Could getting my car towed do the trick ??????
    Thank you in advance for your help.
    Regards,
    Steve.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Push it down a hill and jump start it lol Worked with our old Vec 2.0DTi
    It will force the airlock through.
    Or you could try undo the injector pipes just a bit and get someone to start the car for you when you look at the pipes for diesel...
    Sunerland
    CELES
    Thank you for your reply.
    My friend has a solid towbar, so he said he would come to mine tomorrow to tow it
    Where i live there are no steep hills to go down.
    I was wanting to know if i got my car towed if this would do the trick.
    So your answer suggests it should work.
    Fingers crossed and thanx again , i will report back after we have tried towing and let you know the outcome.
    Kind regards,
    Steve.
    West
    Towing usually does the trick
    Regular Member signum03's Avatar
    worthing
    is it a diesel? when you changed filter did you top up filter housing with diesel? you should do this when a new filter has been fitted??
    East Midlands
    Top up the fuel filter bowl,then get hold of one of these...http://www.screwfix.com/search.do;js...n=submit...and prime the system,don't be tempted to keep turning engine over like i did,and was told that this can ruin the fragile pump apparantly.
    Sunerland
    Thanx for your replys guys, im am going to try getting it towed today.
    The Diesel priming tool, whichv fuel pipe do you conect it too please and where.
    regards,
    Steve.
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    take the inlet pipe of and spray diesel down it start every time.
    Sunerland
    YEYYYYYYYY first class info guys TOWING it worked
    THANK YOU.
    regards,
    Steve.
    West
    Glad you got it sorted bud
  1. How would you cure a air lock from fuel pump to injectors?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd November 2011, 00:16
  2. Hard starting after fuel lines off?
    By Thom in forum Engine & Drivetrain
    Last Post: 19th September 2011, 10:06
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
diesel engine airlock
diesel air lock symptoms
vauxhall diesel air lock
vauxhall astra diesel air lock
insignia diesel vapor lock
diesel car air locked zafira
airlock in diesel car
how to get a airlock out of a vauxhall astra fuel line
vectra c diesel air in fuel line
fuel air lock in diesel engine
How to remove airlock on the diesel
https:www.vectra-c.comforumshowthread.php104422-cannot-get-air-lock-out-of-Diesel-fuel-lines
isuzu280dt airlock in diesel line
vectra airlocked low fuel
vectra 3.0 keep air locking
astra van air lock in fuel
vauxhall vectra fuel system
vectra diesel out of fuel
how to lock insignia engine diesel
meriva b airlock in the diesel system
airlock diesel clio
vauxhall vectra 2.0 dti diesel air lock
airlock in diesel zafira.
airlock in fuel system vauxhall vectra
Airlock fuel
