Thread: Limp mode in idle
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Limp mode in idle
    Quick one for you guys..........
    As i pull away from a stop in 1st gear, limp mode kicks in, if i quickly turn ignition off and on again car drives fine at fast speeds until i stop again. As soon as the car idles then i pull away, limp mode kicks in again.
    Any Ideas?
    Oh, and its intermittent.....
    Russ
    Mar 2007
    Grimsby, Lincs.
    Hmmm, people used to help and and advise on here...........
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Now you did really expect to get an answer at 10.45 did you russ, some of us need our beauty sleep.
    Right what your car is suffering from is the classic vx failing known as limp mode , this can be caused by in the dti,s case anything from egr valve needing a clean similarly the boost sensor or holes in the large hoses between the engine and the turbo similarly check your vacuum hose connection,s for holes or signs of perishing . you can find how,2 on here for cleaning the egr and the boost sensor similarly there is thread,s showing you what to look for with the hoses , failing all of these ask if the is anyone near you with a code reader/tech 2 they can then see what fault codes are being produced and guide you accordingly
    and still loving it
    Mar 2007
    Grimsby, Lincs.
    found the culprit!!!
    the electrical connector on the EGR wasnt 100% connected so the vibration must have been causing the intermittent fault.
    when i pushed it in it made an audible click as the connection made properly.
    Problem sorted. cheers bobssignum, i'd have never thought to even look at that jobby. Gonna pull it out and give it a clean this week though after seeing the pictures!
    Cheers again
    Russ
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Makes sense. I had something similar when I refitted the MAF sensor/pipe the wrong way round after doing the airbox mod on my CDTI 150. What a plonker I was.
  1. EML Limp Mode. Help!!
    By Mission1979 in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 21:57
  2. Limp mode again
    By craig2.2 in forum Engine & Drivetrain
    Last Post: 5th August 2009, 21:05
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp Mode...Again!
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2007, 17:47
  5. why is my 2.0 dti going into limp mode at 65/75 mph
    By new vectra owner in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2007, 07:59
