Results 1 to 10 of 13
Thread: Can U Change Bulb On Sun Visor???
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Default Can U Change Bulb On Sun Visor???
    simple Q folks. every bulb in my car is an Mtec, look brill! but the yellow crap i got in my sun visors is peeping me off. SO, would i be able to change the bulb? and has any1 done this before? many thanks in advance!
    PaZ!
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Bump!
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I can't see why not..uses the same live feed and earth as the interior lighting panel.
    So shouldn't upset the canbus system.
    Usually a bit of a fiddle to get the lens out to access the bulb.
    For compactness, you would probably need to fit a small strip of SMD LED's.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    bumpness!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Just came across this thread, as looking how to change a bulb on the sun visor in my 2.2 DTi SRi Veccy C.
    Couldn't find any info on how to remove the lens, so after a bit of poking around, the lens does not remove!
    When you lift the flap to view the mirror, the whole mirror unit is removed from the visor. If you look closely round the outside, you see little clips holding it in. I used a screwdriver (with the end covered in a sheet of kitchen towel to prevent scratching the plastic mirror surround), and popped out the unit from the top right corner. The unit then just eased out.
    Hope this helps anyone else trying to change bulbs on the sun visor
    Regular Member SRIDAN's Avatar
    Out in the Estate
    5 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Quote Originally Posted by SRIDAN View Post
    What 9.99 for 2,
    Try 9.50 for all 4 EBAY
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Quote Originally Posted by tony-1977 View Post
    i wondered how it came out, this is a big help thanks
    the bulbs that are in there as standard are rubbish and yellowy,another led upgrade methinks.
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    No
    £9.99 per side! i think that a bit over the top?
    Sep 2011
    Birmingham
    Trim : sri
    that sounds steep, does anyone have a pic of the bulb fittings handy, there must be a cheap led equivalent?
  1. boot bulb change to L.E.D
    By justin32 in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 09:34
  2. Sun visor bulb change
    By predator in forum Bodywork & Interior
    Last Post: 25th September 2011, 19:27
  3. How to change a light bulb?
    By LAZZEE RARSE in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 17:59
  4. Bulb change
    By chris_gsi23 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 18:33
  5. how do you change this bulb?
    By wardy in forum Bodywork & Interior
    Last Post: 1st March 2008, 09:45
insignia sun visor bulb
vectra c sun visor
https:www.vectra-c.comforumshowthread.php104403-Can-U-Change-Bulb-On-Sun-Visor
vectra c sun visor bulb
vauxhall sun visor bulb
vauxhall vectra b sun visor lights
