Results 1 to 10 of 14
Thread: tyre
    greenock
    Default tyre
    ok need new tyres on my sri 150
    what do u use and how much did they cost?
    It depends on what you currently have fitted
    This is likely to be Good Year NCT5 215/510R17 91W (about £120 fitted)
    You can easily swapped to any other brand on this size, but there isn't much choice
    Alternatively, you can swap to the 225/45R17 (fit the new tyres to the rear and that way you wear out the previous size quicker) which will work out vastly cheaper in the long term
    The Good Year GSD3 is an excellent alternative, this has been reintroduced due to customer feedback and demand for a directional tyre
    I went through several and thoroughly recommend it, but it was discontinued in the XL rating (at about £160 fitted and as recommended for the 3.0 V6 CDTI)
    I am currently using Good Year Assymetric and it is the next best thing, at about £105 fitted
    Avoid Dunlop TT and GT (at about £90 fitted), I had one set of each and although great on some cars, completely useless on the Vectra C
    If you really want to push the boat out, then go for Michelin (at about £140 to £220 fitted)
    That's my normal tyre of choice, but the range in 215/50R17 and 225/45R17 isn't that impressive (compared to the Good Year)
    Personally, buy the best you can afford
    Dunstable
    Recently bought 2 avons for my sri, 17 inch standard wheels, cost about £115 each budget ones would've been half that...around £60.00 a pop
    greenock
    i deffo dont want budget tyres
    i usually go to 'viking international' pick the tyres up at trade and then pay the extra to get them fitted
    i was quoted £170 for a nct5 to be supplied balanced fitted ect
    i picked one up for under £110 and fitting was £10
    so its a great saving on 4
    i need 4 so rotating them isnt going to help i need 4
    11 Post(s)
    Although I initially liked them when I changed my NCT5's to the GSD3, the constant tramlining soon got on my wick. It actually made driving the car long distances quite fatiguing. In some respects I'm glad they only lasted 10,000 miles (on the front).
    Now running Rainsport2's, and have just swapped the fronts to the rears after approx 11,000 miles and they still have 4 to 5mm of tread left on them.
    In short the rainsports have lasted a lot longer that the GSD3's and the handling is a lot better than when I had the GSD3's fitted.
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    his is the place you want www.elitedirect.com just brought 4 vredestein brilliant tyre mate,
    delivery next day.you will not regret it.
    Regular Member grumpano's Avatar
    North West
    Got the GSD3, on mine. After 6000 mls they drone like mad on the rear. had Kumhos before with no problems. Would get them again.
    Regular Member Mark0's Avatar
    Scotland
    Uniroyal Rainsport 2's. Awesome.
    Worcs/Staffs/Westmids (ish)
    Using Bridgstone ER300's, £92 per corner fitted.
    Wales, UK
    Cant fault my Ultrac Vredsteins, purchased from camskill.co.uk
  1. Tyre help
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2011, 01:12
  2. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  3. Tyre Help
    By leeds_cdti in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 15:07
  4. 215/50/17 tyre
    By jonnye in forum Parts for sale
    Last Post: 14th September 2006, 22:08
