Thread: Magnetic Door Signs
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Magnetic Door Signs
    The Mrs has just gone self-employed as a mobile hairdresser and she does have a good client base already but advertising is always good so was looking at some magnetic door signs like these
    Are they damaging to paint / electronics in the doors?
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    i had some of those a few years back,you have to becareful when you take them off (keep them nice & flat)or they start turning at the ends and make sure that when you put them back on that theres no crap on them, they mark.
    i had mine pinched was working at coventry university came out and gone. they would of made a lot fridge magnets, the gits
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have a mate who used to use these for his Taxi and they made quite a mess which I had to sort out for him. After I polished the car back up again I found that if you make sure the area is spotless and has a decent coat of wax on it, it can seriously lower the damage that happens and also if you can help it try not to keep taking the signs off and on to regulary
    Stockton on Tees
    Paint fade is the only problem i've heard of with these things. The sun fades the paint on show but under the sign is good as new!! A machine polish usually does the trick though. Plus if the area ain't clean then scatches can occur
    UK
    I sometimes use them on my taxi, I only put them on if the car is clean and give them a quick wipe with a baby wipe and them dry with mcd's paper towels. Mine have not damaged the paint but I put them on the lower part of the front doors so it would be less obvious is a mark is made.
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    I made these magnetic signs last summer when I was working. They shouldnt do any damage to the car so long as you put it on a clean car and make sure theres no dirt on the back of the magnetic itself.
    They look ood when on the car, just make sure you take them off and clean them regularly and you should be fine
    Gwent
    Get magnetic signs free from vistaprint.co.uk
  1. Magnetic Sump Plug
    By Z28 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 21:37
  2. Magnetic Man debut album
    By george1987 in forum The 'Off Topic' room
    Last Post: 11th November 2010, 19:23
  3. Magnetic Oil Drain Plug
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2009, 14:36
  4. Tell Tale Signs
    By B00mer in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 20:29
  5. What are the first signs of a DMF going?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2008, 09:35
