Thread: 'Twanging' noise from front right??
    North East
    Default 'Twanging' noise from front right??
    Recently I have been getting what I can only describe as a 'twanging' noise from the drivers side front wheel area. It seems to happen when I go over rough road/bumps etc then sometimes when i expect to hear it over a bump it doesn't do it! I have had a good look in the wheel area and there doesn't appear to be anything amiss. The spring looks/feels to be fine.
    Any ideas?
    It's a 54 plate 1.9 CDTi [150] Estate.
    WGAF#5
    either the spring moving on its mounts -top mount bearing movement - or the spring has broken in its casing and you just cant see it yet
    Regular Member Jezzy's Avatar
    S.E
    If it sounds like someone hitting the chassis with a small hammer, then that's usually the springs jumping. Do a search on here for "spring seat mod" or "spring mod". It involves buying some plastic sleeves from Vauxhall for a few pounds and wrapping them around the bottom few inches of the springs, to isolate them from the seat.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    If you want you can bring it to my garage on Portrack Lane and i can put it on a ramp and have a good look for you. No charge.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like the mormal broken spring vectra sympton
    Regular Member grumpano's Avatar
    North West
    Spring all the way for me mate.
    North East
    I have had my hand in there and I can't feel any broken spring?
    North East
    Quote Originally Posted by r.bailey63 View Post
    Thanks for the offer, where abouts in portrack lane are you and what are your contact details?
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. twanging front springs
    By DARREN R in forum Handling & Braking
    Last Post: 9th July 2009, 11:12
  3. Twanging Noise
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2009, 14:43
  4. Handbrake twanging noise
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2009, 09:44
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
