Thread: 1.9 injector/nozzle swap
    Regular Member HappyHarry's Avatar
    Wolstanton, Newcastle-under-lyme.
    Default 1.9 injector/nozzle swap
    Has any one done this? My 2006 CTDi 150 (67k) has developed a bit of a misfire just above idle, esp. when cold or maybe stopped for an hour or so when it seems to be momentarily running on 3 pots, but is absolutely fine throught the rest of the rev range. It's recently had the EGR and it seems to be unrelated to the issues that was bringing up.
    The stealers helpfully suggested a £800 top end stripdown for starters to 'diagnose'.
    But, a bloke at work has the same engine in his Saab and had a very similar prob which was cured by replacing the injectors, so I thought I'd have a go....Any suggestions/hints? TIA.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    have you done the 3rd injector wiring mod ?
    Hi...According to the VIN no, it falls in the parameters of those with the modified wiring. Sorry, should have mentioned this.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    it may be worth checking the injector plugs, just undo the plugs one at a time a squirt of contact spray and then try. i wouldnt of thought the injectors would be knackered at 67k.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    If you do end up going for an injector change, the replacements will need their values programming into the ECU either TECH2 or OPCOM.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Do you have blue injector plugs then..?
    One thing I would suggest to try mate, tie-wrap all 4 injector plugs on, make them nice and tight then give it a go - sounds strange, and for a matter of pence is well worth a try - it does work
    Thank you all - I shall try all those B4 putting my hand in my pocket. Will let you know how I get on...
    Regular Member kamar's Avatar
    bradford
    my vec started misfire then after afew days got worse and then the spanner on, had it on machine it read p0203 injector circuit open, my mate came round had a look and the 3rd injector wiring wasnt plugged it was loose once he pushed it on cars fine, thank god
  1. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  2. Washer nozzle upgrade?
    By Telly Addict in forum Bodywork & Interior
    Last Post: 16th September 2009, 20:14
  3. petrol nozzle gets stuck
    By STAV in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2007, 00:48
