Results 1 to 10 of 11
Thread: idle problem when warmed up (3.2 v6)
    Brockley-south london
    Default idle problem when warmed up (3.2 v6)
    I've recently got a prblem with my 3.2 sri (53)
    When the car warms up it begins to hunt on idle then the warmer it gets the higher the revs go up to about 1500rpm
    When it's been on for a while it'll rise to 1600rpm then suddenly drop to 1k then start to rise again.
    It's only done this since i changed my plugs at the weekend and i've doubled checked all vacums
    any pointers to what it could be
    cheers in advance
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Hello mate
    I'm not sure whether the idle is controlled by an idle valve on these engines or by the throttle butterfly.
    Either way, grab some carb cleaner and give the valve or butterfly a good clean. If there is a valve (someone here will confirm i'm sure) then make sure you oil it up with some 3 in 1 oil to stop it sticking.
    HTH
    cheers i'll try that. I'm quite sure they don't have ICV as it's fly by wire.
    I'll try some cleaner but as it only happens when it's up to running temp it might not slove the problem.
    cheers
    anyone else?
    Mileage : 55000
    They do have an air control valve.
    where abouts is it. cheers
    Mileage : 55000
    thank you
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Mine stopped after I took of the intake plenum and then removed the black plenum under that, It had a Vacume hose that had worn and was hanging on by its teeth Replaced and Idle was fine at 600.
    might be something else to look at
    cheers
    Full Member
    Mar 2007
    Finland
    Quote Originally Posted by andymagee1982 View Post
    Was this worn vacuum hose inside the black plenum, or somewhere else?
  1. idle problem
    By speedfreeride@yahoo in forum Engine & Drivetrain
    Last Post: 6th June 2009, 19:15
  2. idle problem
    Last Post: 3rd June 2009, 00:30
  3. 2.0T idle problem
    By peteopc in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:35
  4. 2.2 16v - Idle Problem
    By SNODDY70 in forum Engine & Drivetrain
    Last Post: 24th March 2009, 09:29
  5. Idle problem?
    By dawn brown in forum Engine & Drivetrain
    Last Post: 16th January 2008, 01:50
