Results 1 to 10 of 28
Thread: Fan on speed 1?
    Oct 2007
    Scotland
    Default Fan on speed 1?
    Looks like my heater fan doesnt work on the 1st speed. Used to be able to hear it start cos it had a little squeak but now the squeak has gone. Havent checked in detail (whether the fan doesnt work or the squeak is fixed :P) but I scanned through the forum last night and noticed people having to replace resistor packs when they didnt have fan speeds 1, 2 or 3. Just curious if this could be the same issue or is it more likely that my squeak is fixed?
    Regular Member jordib's Avatar
    Londonderry/Dundee
    i noticed this this morning, i dont know if the 1st speed is just so low that i just cant hear it or feel it or if it actually isnt workin.
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    I think this is a common problem that the fan speeds don't work on 1 and then on 2 and eventually 3, but people usually notice by then.
    It's some sort of filter that needs changing if I remember correctly - someone should come along soon that knows.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Could it not just be the rotating switch worn??
    Oct 2007
    Scotland
    OK, just checked it.
    Fan ISN'T working on speed 1. Works on all other though. Isnt the switch cos the fan wont come on if I press the air-con button (it should come on at the lowest speed). When I set the fan to 1 or press the air-con button I can hear a click from behind the glove box which I presume is the relay so I guess that is working ok.
    Ideas?
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    There is a thread on here which covered this issue in much detail, I recall putting up pics of the fan/heater circuit, and the relays being used.
    Certainly worth using the search to try and locate it.
    BTW dont assume because you can hear the relay clicking, it's working properly, I believe in that post I mentioned the fault turned out to be a relay.
    The members fan would only work on certain positions.
    Oct 2007
    Scotland
    Cheers 67688c. Found your diagram but not sure if it tells me anything. Not all that versed in reading wiring diagrams and not too sure if it tells me anything about my problem. Cant see the air con button in the diagram or the control switch (1-4).
    OK will check the fuses first.
    Oct 2007
    Scotland
    Checked the three fuses but they are ok. Can anyone point me in the right direction?
    Oct 2007
    Scotland
    Checked the switch. Have green, blue, grey and red/black wires at the switch. Found that I have current through all the wires (at the switch) when the switch is at 2, 3 and 4. when the swicth is at 1, I have current through all the wires except the green one. When fan is off and A/C button pressed, I have current through grey and red/black.
    Can anyone let me know if this points more to the relay or the resistor pack?
    Oct 2006
    southampton
    15 Post(s)
    I have the same issue at the moment so watching this with interest
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. Speed limits & speed cameras.
    By kentish_bloke in forum General Chat
    Last Post: 15th February 2010, 21:22
  3. Z22YH 5 speed or 6 speed
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 11:56
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. Speed Camera's / Mobile speed traps M6>M61
    By suj786 in forum General Chat
    Last Post: 10th March 2006, 22:38
