Thread: Bulb change
    Regular Member chris_gsi23's Avatar
    Leeds
    Default Bulb change
    Hi, plz could some help n tell me how you go about changing the NSF headlight Bulb without dismantaling the front bumper n taking the headlight out. Help would b greatly appreciated
    Oct 2007
    Scotland
    Just some patience and little hands I'm afraid.
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    hi mate, if it's a facelift then pull out the washer bottle filler neck, it comes out easily and then you'll have enough room to do it, i've just changed mine to hid's and i've also changed the side light bulbs and main beam, then slackened the bumper off and fitted silver indicator bulbs, whole lot took about an hour and half........i did the drivers side by removing the air box etc
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Facelift here, so my comments won't really work for pre-facelifts.
    Driver's side is harder - either remove the airbox or just put up with scratching your hands and wrists getting it in, it is possible.
    Passenger's side is easier - remove the washer bottle neck, but you should be able to reach round and under.
    If you're fitting HIDs not just changing bulbs then it's a much better job if you drop the bumper rather than try and squeeze the ballasts in with the bumper still on.
    Full Member izonoky's Avatar
    Aug 2007
    London
    Have a look in the 'how to' section there's some good posts on this topic there.
    2.2 Direct SRi
    Regular Member muffking's Avatar
    I used my missus makeup mirror to see the clips properly from behind the bulb as you should have enough access with the battery compartment open.
    Leeds
    Thanks guys, I have an 06 facelift 150 cdti. My 1st vectra n I have to say I'm really pleased with it.. I've always had the older vauxhalls this is the newest vauxhall i've had..
    Leeds
    Rite I have changed the bulb, and I have 1 of 2 options without loosening the bumper or pullin the washer bottle neck. 1st open the bat cover n take the fuse box cover off. Then squeeze ur hand through the gap but u will get scratched or 2nd, get ur 5ft 2" girlfriend 2 listen to wat ur telling them n get her to put her small hand in n follow ur instructions. Job done.. Lol
  1. boot bulb change to L.E.D
    By justin32 in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 09:34
  2. Sun visor bulb change
    By predator in forum Bodywork & Interior
    Last Post: 25th September 2011, 19:27
  3. and I thought Vec bulb change was bad...
    By chewy71 in forum The 'Off Topic' room
    Last Post: 17th May 2011, 09:17
  4. How to change a light bulb?
    By LAZZEE RARSE in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 17:59
  5. how do you change this bulb?
    By wardy in forum Bodywork & Interior
    Last Post: 1st March 2008, 09:45
