Thread: New griffin
    s wales
    Default New griffin
    Got the new griffin for the V of my sri xp vectra please any info on the best and possibly easiest way to fit ' ive seen a few suggestions on here '1 said remove old glue new there must be more to it than that'if not great'another said something about remove the V and old griffin and cover hole made prior refit of new griffin something like that try as i might i can't find this particular info again 'anyway all info appreciated Mel
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    if its the 93mm version you need to snip the legs and file the stubs flat.. then you araldite it onto the V.. However the existing black plastic backing will be covered in the silver pins where the old griffin was attached.. so you can either knock up some new black plastic backing now or do it later on... i glued it on and decided to come back to it another day, or maybe not...
    Full Member spennny's Avatar
    Blantyre
    I used an old DVD case as a backing plate, glued it on and bingo, still on today..... ok its sitting behind the wheelie bin as i have the irmscher grill now
    Jun 2009
    South Coast
    an old dvd case.. now theres an idea... nice tip..
    s wales
    Quote Originally Posted by Caveman_nige View Post
    Thanks for your reply .mel
    s wales
    Quote Originally Posted by spennny View Post
    Thanks for your help this is the way i'll fix it i hope . mel
    Blantyre
    Quote Originally Posted by caveman_nige View Post
    an old dvd case.. Now theres an idea... Nice tip..
    Quote Originally Posted by melo View Post
    thanks for your help this is the way i'll fix it i hope . Mel
    Just cut to a circle that fits in behind it and glue (ARALDITE) the badge on
    hth
  1. Replies: 2
    Last Post: 21st August 2011, 11:38
  2. Not a Vec, but still a Griffin.
    By mitch1965 in forum Quick Photo Album
    Last Post: 10th December 2009, 00:53
  3. the new griffin
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 19:30
  4. The Griffin is gone
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 22:36
  5. Red griffin
    By ed taylor in forum General Chat
    Last Post: 30th June 2006, 16:57
