Thread: (( Timing belt ))
    Regular Member VectraGezza2010's Avatar
    Jan 2010
    Anstruther
    Default (( Timing belt ))
    Helloooo was just wondering at what mileage does everyone with CDTI 150 start thinking about having there timing belt/Chain checked out ?
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    They're not 'due' until 100k, but I changed mine at 87k. Oh and it's a belt.
    If you have the dreaded swirl valve problem, then it's an ideal way of killing two birds with one stone.
    Regular Member kamar's Avatar
    bradford
    just gave my car to have the belt changed, got the kit from dealers for £96 and few pence
    Aug 2009
    sheffield
    do the water pump/aux belt ,at the same time. saves going back later.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i did the belt on mine at 100k and the belt is still perfect only the tensioners were a bit noisy also the water pump was still perfect with no wear in it whatsover
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Should realistically be looking at 60k and no more before changing the timing belt/pulleys
    Thats not really why you change it.
    Ideally, you can ask for it to be checked at every service
    As above, it should last to 100K miles
    Once the car is out of warranty and/or above that mileage you may want to half the interval
    Not sure if the cambelt also drives the water pump, if so then it can be wise to replace that at the same time
    Also any other connected or driven belts, replace them at the same time
    Leeds
    Did mine at 56k as the waterpump was noisy - better safe than sorry
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
