Results 1 to 10 of 11
Thread: cigarette lighter/ power socket removal...
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default cigarette lighter/ power socket removal...
    as above has anybody got a step by step guide, for easy removal of the cigarette lighter/power socket in front of car it moves a bit but cant seem to get it out?????????
    thanks Paul
    Dunstable
    'tis a pain to remove, IIRC there is a lug that locks it in place when it it pushed into the console. I removed mine on my old '03, but did it when the centre console was removed so I could access it from underneath which was easier but still fiddly!
    Jan 2010
    Liverpool
    I think the actual cig unit will be the same as the Vectra B's.
    If this is the case then the metal part needs to be prized out of the plastic section. It should then come free.
    leighton buzzard
    there seems to be be something attatched to it so it wont come out of hole
    Jan 2010
    Liverpool
    The unit is an odd shape as it has a part where the courtesy light fits on the plastic section. When its all together you can't manouvere it out the hole because the metal section makes it too long. You need to pull the metal bit out first and then the plastic part will come out. There are some retaining clips that keep the metal part attached, so its a pain to remove.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    i too was about to ask this question as ive got the new style 12v power socket to go in my 03 reg vec, i tryed today on a vec c that was being crushed at work , and ended up smashing the surround and lighter socket to bits .
    has anybody got some photo's of the proper way to remove the cig lighter socket without smashing up the car???
    Hanging Heaton / Batley
    20 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I open the ashtray... then remove the gear surround...
    That free's up some space to get the full ashtray out. clip seems a little tight on the right side but just pull out and up towards the hand brake...
    The cig lighter surround is the same, out and up. and you can even pull the cubby hole out...
    It can all be done by hand within seconds... then you can get to it from behind
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by leemarksmith View Post
    cheers mate will give it another go tomorrow
    [Ex]Admin Duncan's Avatar
    http://www.vectra-c.com/forum/showthread.php?t=37071
    Just came across this thread whilst searching for another thread, the one I've just linked to! lol
    leighton buzzard
    cool
  1. Cheap Cigarette Lighter Socket USB ports
    By nibblitz in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2013, 22:36
  2. Cheap Cigarette Lighter Socket USB ports
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2013, 00:46
  3. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
vectra c cigarette lighter removal
vivaro cigarette lighter removalvectra c remove lighterchanging lighter in zafirachange cigarette lighter vectra ccorsa c cigarette lighter replacementcorsa 2010 cigarette lighter removallighter vectra remove cigarettevectra c cigarette lighterhow do you get the cigarette lighter out of my vauxhall insignia 12v charger not working vectra chow to remove vauxhall vectra c cigarette lighterremove cigarette lighter socket insignia vivaro remove cigarette vectra b lighter corsaremove front power socket zafira bvauxhall astra cigarette lighter replacementopel zafira how to remove lighter panelhow to remove lighter from opel monzaremoving vectra lightervectra lighter disassemblyhow to.remove cigerette lighter socket zafira removing vectra c cigarette lighteropel vectra c lighterremove accessory socket 07 zafira
