Results 1 to 10 of 30
Thread: major help egr
    newcastle
    Default major help egr
    hi i cleaned out my egr and did the drill bit put back together went to turn on car but just coming on enginge is making massive noise smoking out exhaust and no rev is this normal
    West
    sounds like you've furked something up big style
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Is everything bolted back together on the EGR ok, did you re-use old gaskets or buy new ones, sounds like there is no seal on the EGR/manifold.
    newcastle
    well no it didnt same on how to to change gaskets maybe when i carb cleaned it still wet a leave it 10 im ****ting it now
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by astratovectra View Post
    It'll be ok, just remove it again, check it all over and refit making sure everything is as it should be.
    newcastle
    wonder if it cos i wiped some carb cleaner in the other end of manifold where egr fits
    Lancashire
    Trim : XP NAV
    Shouldn't be, as thats the usual way to clean it
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    As Dan BlackSRi said, it sounds more like you've got gasket problems, put your hands all round the gaskets while it's running to see if you can feel or hear anything
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    you cant beat advice like this can ys pmsl
    mucker dont panic like everyone have said it would just be a gasket or something or you have missed something out ,check all connections and feel for a good seal (when cold)
    newcastle
    ok took it of got a burn in smell and bit of smoke coming off from egr to manifold think cos it bit wet still
  1. Major Oil Leak!
    By Micky86 in forum Engine & Drivetrain
    Last Post: 5th February 2013, 18:18
  2. Major Service
    By danno in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2010, 22:04
  3. 2.0T Major Problems!
    By cold-chilli in forum Engine & Drivetrain
    Last Post: 24th March 2010, 17:45
  4. First major mod.....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2009, 08:32
  5. hi need major help
    By andyg12 in forum Troubleshooting
    Last Post: 10th November 2008, 22:14
