Results 1 to 10 of 20
Thread: cleaning the swirl pots
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default cleaning the swirl pots
    is there a how on how to clean the swirl pots on a 1.9cdti 150 on here.
    cant seem to find one. if not could anyone let me know how you do it as im not very mechanicaly minded. any help would be greatly appreciated.
    Sep 2009
    swansea
    Trim : Club
    ive also just popped of my engine cover & low & behold my swirl bar is off
    gutted!
    how do i go about fixing this?
    what damage can it or has it caused as i dont know how long its been like it.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    if its off dont worry too much it all depends on what position they are stuck in mine was off over 6months and i hardly noticed any difference at all there is a quick fix on the how 2 on here to fix it with tap washers but this all depends how long it lasts the only real way to fix it is to get your inlet manifold replaced which is 470quid plus at a dealer or if you a mechanically minded and quite good with cars you could do the work youself but its quite a job
    and you cant clean them as such the only way to clean them would be to do the 10k boost clean on the how 2 on here thanks
    Wales, UK
    Not too sure if it causes damage but many people have driven for a very long time, not knowing the bar has come off, like yourself and have continued to drive it!!
    There is a thread here somewhere on how to fix it for literally a couple of pound. It may last a long time, or it might just fal off again. If you find this thread in question, then may I siggest araldyte glue. Its very strong !!
    Sep 2009
    swansea
    Trim : Club
    any linkys to the tap washer thread guys
    Jul 2009
    Brighton
    Unhappy
    Quote Originally Posted by monty2000 View Post
    gutted!
    If it's broken, then you won't be getting the correct combustion in the cylinders. Depends which flap is stuck, and whether it's open/closed.
    Ultimately, with the dirty combustion, your EGR valve will also get coked up prematurely, as may the other swirl valves/flaps, making matters worse.
    Bad news is, the proper way to fix it is a new inlet manifold with associated control unit. Sorry.
    There is a link on here somewhere about the Pieburg tumble flaps, or swirl valves to you and me.
    Had mine done on warranty recently,not much help to you though. Sorry to be the bearer of bad news. Blame it on VX for a great design.
    Daz
    Sep 2009
    swansea
    Trim : Club
    i took out a lifetime warranty with my car. wonder if it would be covered
    Sep 2009
    swansea
    Trim : Club
    got the bar out. not v easy i must say. gonna go to b&q afer work to c if i can get thoose washers.
    do the plastic inserts have to be in a certain position the seem to move around quite easy. also when the engine is running is number three suppose to spin around?
    i cant quite see how it works does the swirl bar simply push into the holes?
    Sep 2009
    swansea
    Trim : Club
    £191 bucks for the part from the stealers. he also recommened that the motor be changed too
    Sep 2009
    swansea
    Trim : Club
    ah i see now the swirl bar sits on the pointy bits that stick up. not push in
  1. Are my swirl pots leaking?.
    By felixx in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 21:15
  2. Manifold swirl bar/pots
    By rob123 in forum Engine & Drivetrain
    Last Post: 1st June 2010, 18:58
  3. Checked the Swirl Bar and pots-think they are OK, please check!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 14:29
  4. 2.2DTi blue smoke after fiddling with "swirl pots"
    By Celes in forum Engine & Drivetrain
    Last Post: 19th March 2010, 00:45
  5. CDTI 150 swirl pots
    By crgv6 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 13:24
