Thread: Idle bounce on 3.0CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Idle bounce on 3.0CDTi
    I've noticed that sometimes when the engine is warm, idle bounces for 100rpm and then drops back. Sounds as if I blipped the throttle.
    Any ideas chaps?
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Not noticed it on mine, so I am not much help, Sorry.
    That's quite normal on a high mileage VX car!
    I managed to trace that to the dirty IAC Valve on my previous Vectra B 2.0
    I've also seen it caused by dirty EGR
    Mine does it too as the engine swaps from cold setting to hot setting, more noticeable on very cold mornings, as the revs start at about 900rpm and it then increases them slightly before dropping down to about 700rpm
    The same also happens when the air con is at the borderline temperature for operation
    I also have my suspicions that the air con actually operates below 5'C when the handbook says it shouldn't
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That's what mine's been doing since the EMS update when I got the SCV's replaced.
    What the problem here is that the revs jump up randomly when it's fully warmed up.
    Quote Originally Posted by Celes View Post
    That is abnormal, sounds like the EMS wasn't calibated after updating to take into account component wear and tear
    Remember, when the EMS is updated all the settings are put back to default
    The EMS then has to relearn the car, this can take between 1000 and 5000 miles, depending on how often you drive the car and how much mileage you do
    Mine relearned my car in about 4 days
    One other consdieration
    The revs on my car were varying after the cambelt change, the dealership corrected this as part of the work and before I left the premises
    This might also explain why it took them four hours instead of the book two
    I assume there is a sensor that can easily be detached or moved
  1. Rattle / bounce at rear over uneven ground
    By mutley-k666 in forum Handling & Braking
    Last Post: 12th February 2013, 05:59
  2. wind delfectors do u ave any trouble with window bounce?
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 13:52
  3. Bounce bounce to the sound of the springs
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 13:38
  4. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
