Thread: Oil warning light
    doncaster
    Default Oil warning light
    Hi, just bought a 1.9 cdti design, the orange oil warnng light has come on, ive had it serviced today, the light came on, on the way home. The garage were aware of the problem, and checked the oil pump etc.. any ideas guys?
    Full Member Big Sig's Avatar
    Orange oil light, is that the oil level light?
    Regular Member djr69uk's Avatar
    Midlands
    low level or faulty sensor perhaps?
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Is that the oil light, because that is red isn't it? - This is low oil level or low oil pressure.
    Orange oil can on the dash (pixel display), would mean that you are due a service, and the service indicator has not been reset....but this only comes on at start up for about 10 seconds.
    The other thought for oil can on orange pixel display....could it be that your Diesel Particulate Filter is clogged, or your diesel fuel filter needs purging of water.?
    Just thought, that would be the spanner symbol wouldn't it. d'oh!!
    Worcs/Staffs/Westmids (ish)
    Quote Originally Posted by admob View Post
    Please clarify....
    Was the oil light on when you brought it?
    how long have you had it before you got it serviced?
    did the light only come on after having it serviced or was it already on?
    Have you checked the oil level?
    In addition to the other suggestions, It could be oil pressure problems caused by using a very wrong grade of engine oil.
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Here's a trick one for you,
    My colleague had a Japanese car, he put a pint of water in the oil filler instead of his radiator header tank. - accidentally of course.
    After running it home that night, he took it to his local garage and had the engine drained and refilled with fresh oil.
    His symptoms were the same as yours from that point...the car ran fine etc, but once it got warm, the oil light came on.
    It was thought that the water had got under the oil on the crank shaft or another part, and caused sufficient wear to affect oil pressure when warm.
    He part ex'd it a week later!!
    doncaster
    hi, i got the car on satdi, driving home the orange oil can light came on, i stopped and checked the dipstick, it was fine, it comes on about 10 mins into journeys. i had the car serviced on tuesday, on the way home, the orange light came on again, i went back the next day, they think its the oil pressure light, and suspect a dodgy sensor, the red light is the low level warning. There is deffo oil in the engine, and a new oil filter. v strange??
    No its not. the red light is low oil pressure. Is it an oil can with a spanner or an oil can with wavey lines under it?
    doncaster
    orange can with wavey lines under neath...
    Oil can with wavey lines below it is the low oil level indicator, if the oil is up to the max mark on the dipstick the sensor could be faulty.
  1. Warning Light
    By chrissy white85 in forum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vectra c oil light
https:www.vectra-c.comforumshowthread.php104228-Oil-warning-light
vectra oil light came on
vectra c oil can light
signum oil light popping up
oil light vectra c
Where is oil pressure switch on vectra 19cdti oil light on vauxhall vectra on idlevectra oil warning lightoil light on vectra cvectra c 06 red oil light on whyvectra c oil light onopel vectra oil lightvectra orange oil lightvectra c 1.9cdti oil lightvectra c orange oil low lightoil light on vectra c fault when i should check oil on vectra coil warning light on vectravectra Red engine oil light when brakingoil light comes on too soon vectra cred oil light on vauxhall vectra 2003how much oil when oil light comes on vectravectra red oil light onreason for orange oil light on vectra c 1.8
