Results 1 to 10 of 13
Thread: Crankshaft Pulley
    KENT
    Default Crankshaft Pulley
    Oh No!
    Started the car up (2.0 dti) today and heard a loud bang under the engine. Had a look and thought nothing more as nothing was obvious.
    While driving a warning light (yellow car with spanner) popped up and the red battery light came on.
    I stopped and pulled over as the temp went ski high and power steering failed.
    AA towed me to my local town garage and they can see the crankshaft pulley hanging off.....
    find out tomorrow whats going to happen.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Normal thing im afraid. Just a replacment pulley needed as long as you didnt cook the motor.
    KENT
    didnt drive for long... stopped when saw temp raise up!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yeah as long as you didn't let the engine overheat you'll be fine and all it will be is a new pulley. But do not buy a cheap part, buy a genuine vx one as the cheap ones rattle forever more.
    The reason you lost the power steering etc is because the belt runs the alternator and the PS is electric, the belt also drives the water pump, thats why it started to overheat
    KENT
    oh i see!
    Great to know. It was a loud bang but didnt see anything and the lights popped on later. Hope its not expensive!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Will prob be a couple of hundred mate, cheaper if you don't fit a genuine pully but again I wouldn't recommend it. There is a How 2 on here if you fancy trying it yourself
    KENT
    I wouldnt have a clue!!!!!! I can just about put diesel in lol
    Nottinghamshire
    Quote Originally Posted by 123ashleyp View Post
    Best avoid the DIY option then. A new genuine pulley is about £150 - as above, don't risk a cheaper one because the extra vibration they can cause may cause damage and is very annoying. Also make sure that the bolt that holds the pulley into the crankshaft is replaced - the old one will probably be in very tight and it's had a hard life, so it's best not to re-use it especially they're only £10.
    KENT
    Garage is £400 - fitted. The pulley and couple of belts have gone. The pulley can be seen hanging off
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Find another garage mate, that is far too much, also there is only one belt fitted
  1. Crankshaft pulley. Vec c and b ??
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 18:43
  2. Weight of crankshaft pulley
    By tosh23 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 08:26
  3. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  4. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  5. Yet Another Crankshaft Pulley!
    Last Post: 13th January 2008, 00:27
