Results 1 to 10 of 16
Thread: fitting new springs
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default fitting new springs
    im going mad i have the shock off the car but that ####### nut on the top i cant get anything to take it off with because you need a t50 torx in it at the same time anyone got any ideas pleaseeee
    Regular Member Jezzy's Avatar
    S.E
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I ended up paying for mine fitting...
    But i saw a thead the other day where someone jammed or welded a spanner on a socket... then the torx bit slips down the middle...
    I tried gripping the shocker at the very top and turning the torx while off the car, wouldn't budge so paid someone in frustration...
    Trim : SRI
    Mileage : 46000
    thanks Jezzy think i will try grinding one tomorrow
    is it ok to lossen the nut while it is still on the car
    East Midlands
    Quote Originally Posted by rickeys16v View Post
    Buy a cheap 22mm swan neck ring spanner,take your grinder and just take a bit of the leading edge off,and there you go jobs a good un.
    And yes loosen a bit before removing from the motor,makes it easier to undo when its off.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I bought a deep 22mm socket & ground a couple of flats at the top, it worked a treat
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I use a vortex socket set, the ones with the hole through the back
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    i always loosen the nut with the weight on it before i take it off as helps ,,,
    Trim : SRI
    Mileage : 46000
    stupid question but do you turn it anticlockwise to to take the nut off
    Oct 2007
    Leicester
    Trim : Elite vxline
    Mileage : 80000
    yes mate
  1. fitting new springs
    By redross555 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 21:21
  2. My Car after fitting springs!!
    By Sean-2.2Direct in forum Quick Photo Album
    Last Post: 22nd October 2009, 22:00
  3. Fitting springs
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 19:10
