Thread: vectra c day running lights
    slough
    Default vectra c day running lights
    OK right so you want auto day running lights.
    first take the key out of the igniton then if you have the 3 positon light switch ie: off, side lights, and on. turn the switch to the side lights positon whilst gently pushing on the knob. the switch should pop back into the dash slightly. now whilst turning the knob towards the lights on positon and holding the pesure pull on the knob and the switch should come out, now disconect the loom from the switch buy lifting the blue leaver.
    once done now put the key into the igniton and re connect the wiring loom to the switch. now check to see if the lights are on if they are turn the switch to the off positon the lights should still be on. if they are then take the key out of the igniton and the lights should go off. if they do pop the switch back into the dash and job done
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    would this be dipped beam or sidelight
    Regular Member madman's Avatar
    nottm
    prefacelift or facelift. doesnt work on my 'pre'. only if i leave the loom disconnected
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by madman View Post
    More to the point Full or Half Can and do the rears come on, sounds like a safety feature to me so you don't lose all lights if something breaks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Affraid to say it is a safety feature, drls only come on with the ignition but I am sure they go off when the dipped beam is switched on
  1. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  2. led running lights
    By triple595 in forum Styling
    Last Post: 21st April 2011, 14:01
  3. running lights
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 08:26
  4. LED day running lights
    By trucker in forum Insignia car chat
    Last Post: 18th June 2010, 11:26
  5. any one fitted the led running lights to there vectra c
    By howardc03 in forum General Chat
    Last Post: 1st November 2009, 19:49
