Results 1 to 10 of 14
Thread: Oil Level Warning Light issue
    Regular Member Blagmeister's Avatar
    Warks
    Default Oil Level Warning Light issue
    Having had my oil level warning light come on intermittently a day or so prior to my 120K service I didn't take too much notice as it was going in anyway. However after getting the car back from the service [its now driving much better] I am still getting the oil level warning light come on when the car is fully warm. There is no problem with the oil level as the car has had a flush and refill as usual.
    Any suggestions as to what might be causing it? Duff sender unit perhaps?
    Over to you gurus....
    Blag
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi B
    allmost certainly the sender,it is the oil level light and not the oil pressure light.just to be sure!
    Warks
    Hi JonnyB
    Yes it is the level light and not the pressure light. I had a feeling it would prolly be the sender as the level was ok. Only thing is where to find it? I have got a gut feeling that there might be a sensor in the sump for this which means dropping the sump cover off in which case it can wait until the next service!
    Jul 2009
    Engine : 20 Dti
    what year ,model,engine have you got,
    Warks
    It's an 05 1.9 cdti 150 Elite estate
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The OLS on my 1.8 is mounted in the side of the sump on the front. Unclipping the wiring will remove the warning - if you are sure it is erroneous.
    Jul 2009
    Engine : 20 Dti
    yes your right Blagmeister it's a sump off job,straight forward then.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So there is no way of simply disconnecting it without removing the sump? I always hate having to remove sumps on cars, the oil dripping is a pain. I would have a look at the engine bottom end while I was there though, and check all the bolts are all tight.
    Sunny Dartmoor
    Looks like i have the same problem,warning light has come on 3 times in a week and level wasn't low at all,how much of a job is it to remove the sump????
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    PITA if you ask me. If it was my car, I would disconnect the sensor and check the oil more regularly. IMO it isn't worth the hassle and mess of removing the sump.
  1. Oil Level warning light
    By Bren G in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2012, 21:55
  2. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  3. Intermitent Oil Level Warning Light - 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 15:06
  4. Coolant level warning light
    By phils in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2011, 21:22
  5. Oil Level Warning Light
    By Gogs67 in forum Engine & Drivetrain
    Last Post: 16th November 2009, 20:25
