Thread: put shark fin ariel on vectra. and it works
    tyne and wear
    Default put shark fin ariel on vectra. and it works
    ok attempted putting shark fin on today after seein another member had done so thought id use the link in his post to get one off ebay 9ish pound alltogether
    fitted and tested allmost all channels work apart from one has a slight little static in in but you couldnt tell unless you were listerning for it so i thinks its a sucess yay!!
    i took a couple of pictures while i was doing it might make a how to when i get five i didnt have to undo all the inside trims just at back below boot pulled down and reached under when i put back the was a slight crease in the linen but it just rubbed out so im happy.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Great mod
    what did you do about the rear water jet
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    tyne and wear
    Quote Originally Posted by Thunder View Post
    Great mod
    basicaly it was pritty easy unscrewed base from the fin drill hole in metal base, drilled hole about 45 degree in shark fin(then notched a lil piece out at top ass the washer has a lil nipple thing in it) threaded water pipe through base then shark fin put the jet on only a little other wise it was to tight to go in hole once ine hole push the pipe onto the jet properly. screw base back together and tht basicly is it.
    Sunny Dartmoor
    Looks very smart..........
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Nice one mate
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    very nice
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    Looks great.
    Do you if this wil work if you also have the GPS-antenna same place.
    Mine is a wagon with CD70 Navi
  1. Insignia shark fin on Vectra
    By sulten in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2011, 21:20
  2. vectra c shark fin?????????
    By dannyjpuk in forum Styling
    Last Post: 3rd April 2010, 10:25
  3. please help, I Want a shark fin ariel
    By bushygrunt in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2009, 04:05
  4. shark fin ariel
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 20:49
  5. Shark Fin style Ariel - Anybody Fitted One ?
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2008, 00:56
can I fit a shark fin antenna to a Vectra Elite
vectra c super shark fin
shark fin aerial for vauxhall vectra
shark fin aerial vectra c
