Thread: gear box oil
    Regular Member i5aces's Avatar
    andover
    Default gear box oil
    when my car is cold the gear change between first and second it "crunchy"
    i have been having a read around and read that you can change the oil on the f40 gearbox, my car is a 3.0 cdti so i think this is the gearbox i have,
    it says to put in 2.2 ltrs of manual transmission fluid and that should sort it out could anyone confirm this is correct, as i once it all turns up i will be booking the car in to have the springs, ARB's droplinks and rear trailing arms replaced and was thinking to get this done at the same time,
    Regular Member Jezzy's Avatar
    S.E
    If you have the F40, then you take out the 3.2 litres that are in there, and put in 2.4 litres (not 2.2); although the later cars already come with 2.4 litres.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Sorry to 'hijack' but anyone got an idea of the price for the filler and sump plugs??..the sockets on both of mine are us...
    S.E
    Quote Originally Posted by nikroc View Post
    For the gearbox (and which gearbox?) or the engine?
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    sorry,the f40 gearbox...
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    the drain plug should be changed anyway on the F40 box as it is a one use item only,the new plugs can be reused
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    thanks..the original plugs are chewed up and a royal pita to get out n will deffo need replacing. Just wondering on price of them,not that i got much choice.
    S.E
    About two quid for the drain plug, and a pound for the top plug.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    kool...thanx very muchly fella
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
