Results 1 to 10 of 13
Thread: unusual tyre wear
    May 2008
    Wiltshire
    Default unusual tyre wear
    Have just had MOT,car passed, guy said both front tyres have worn on the inside. I had tracking done last year and had it checked straight after MOT, all ok.
    The tyres on the front are Khumo usually a good tyre, but at 90 quid each for 215/50/17 i really want to get this problem, if that is what it is, sorted out. tyres have done about 10000 miles and have been on the front of the car for about a year and a half.
    i drive pretty sensibly, I do tow a caravan however about 2 times a year, once being to france covering a 1000 miles, could that cause it?
    I am worried that it could be a rubber bush somewhere, but happenng to both sides is weird! any ideas?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like camber or toe out mate.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    It'll be the geometry settings, they are either incorrect are you have worn suspension parts, but as its passed an MOT they can't be that bad, so it may need a 4 wheel geometry setup (like a Hunter system).
    May 2008
    Wiltshire
    agree, but what would cause that , tracking is ok.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by iasha View Post
    Tracking is only making sure all 4 wheels are pretty much pointing in the right direction, the geometry setup checkes and adjusts the camber/toe in/out settings too.
    Apr 2008
    High Wycombe
    Vehicle : Vauxhall Insignia
    Trim : SRI NAV
    Engine : 2.0 CDTI 140
    Mileage : 20000
    I also have Kumho tyres on mine and the inside edge were odd. I took mine to have the 4 wheel alignment done at Imperial Tyres in Swindon and was told the wheels are chopping.
    Alot of garages cant do proper 4 wheel alignment, first place I went to said I had to have new tyres.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by rsocon View Post
    ....first place I went to said I had to have new tyres.
    ..for it to happen again, I can't believe some places, I really can't.
    May 2008
    Wiltshire
    to get some more life out of the tyres before they become totaly illegal, would it be a good idea to up the tyre pressure slightly to wear the middle, may give me a couple of months use. will ring imperial
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Not really mate, all you will do is make the insides more firm. I run my 17's at 38 and they wear perfectly even. Have you lowered it at all? The rear of the sri's are cambered quite a bit but the fronts sit perfectly verticle to the eye. What do yours look like.?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    All your questions answered here http://www.wheels-inmotion.co.uk/index.php under the "technical theory" section.
  1. Tyre wear
    By s2yob in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2011, 22:14
  2. tyre wear
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:08
  3. M.O.T And Tyre wear.
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2008, 20:44
  4. Tyre Wear
    By 24vElite in forum Handling & Braking
    Last Post: 10th February 2008, 19:28
  5. Tyre Wear
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 22:34
