Thread: TURBO help
    southport
    Default TURBO help
    hi ive got a 2.2tdi 03 ,could anyone tell me how to tell me how to check if the turbo is working ,ive only had the car a week or so ,so cant compare performance from when i brought car if the turbo wasnt working, also what sort of rpms does the turbo kick in sorry to sound clueless but thats why im askin lol .
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you only bought the car a few weeks ago, why do you think the turbo is not working?
    One easy way to check is to squash the main air pipe from turbo to intercooler (which is at the front of the car) and get someone to rev the engine. You should feel the increase in pressure in the pipe.
    Full Member Penfold101's Avatar
    Turbo should kick in around 2000rpm 'ish. If you sit in about third with the revs at around 125-, then put your foot to the floor, you should feel the surge when it kicks in - it's quite noticeable...
    southport
    cheers ste ,its just some one on here said they had a fuel issue like mine low mpg less than 30 , and said it might be that the turbo was not working and that would eat the fuel up so just trying to eliminate that as a cause, i hear a slight whistle when i pres clutch in while driving, the power seems okish but not as good as what i belive it should be from what ive read on here .
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    If the turbo wasn't working you'd know about it as 0-60 would take half an hour and you wouldn't get over 60mph. Probably rev no more than about 3000. Car would be completely dead.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by Ste View Post
    Also - you should hear the whistle as it spools up - drive with the window down and give it a bit of beans you should hear it, and notice it surging at about 2K revs, as mentioned above.
    HTH
    southport
    ok ive can feel the pipes get harder as the car is reved up and now ive cleaned the egr and noticed better acceleration from second gear and slight improvement in third , im just hoping the mpg is improved now ,should i do a fuel filter change !!!!!!!!!
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    also it would whislte (when working)
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by dannyjpuk View Post
    Not necessarily always will a Turbo whistle.
    If the vane is nicely balanced within it's bearings and the car is a bit miley, the whistle isn't always there.
    West
    Quote Originally Posted by spm1966 View Post
    It won't hurt to change all the filters & oil tbh... give the boost sensor & inlet elbow & good clean too, you will deffo notice a difference
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
