Thread: Vectra-B: Knocking noises & planned bush's change-WHICH ONES DO I NEED?
    Birmingham
    Default Vectra-B: Knocking noises & planned bush's change-WHICH ONES DO I NEED?
    Right folks,
    Im planning on changing the bush's on my Vectra within the next couple of weeks, before I got out an buy them, can someone advise me as to what I will most probably need?
    First the car, its a:
    "Vectra-B 2.2 SRI DTI, 2001/51, Hatchback-5-speed Manual".
    Symtoms:
    Kncoking noise on rear, like something is loose. Clunking noise on the front over bump's, again like something is loose.
    My suspiscions:
    Rear Rose Bush's, Rear ARB Bush's, Front Drop Link's, Front ARB Bush's.
    WHAT ELSE COULD IT BE?
    ARE THESE USUALLY THE MOST COMMON ONE'S TO FAIL OR DO I NEED SOMETHING OTHER THAN THE ABOVE?
    Please ASAP as im on the verge of ordering them soon!
    Thanks in advance.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Hello ???
    Bye bye Vec B
    - Hello Siggy!
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Sounds right to me... I am about to change the same parts on mine for the same reasons... if the noise still exists then i will do the trailing arms next
    Wales, UK
    My old Vec B 2.2 petrol had the same problem and was curred by new bushes, cant imagine what else it would be really. Your struts are ok I assume ?
    Birmingham
    Quote Originally Posted by mark_647 View Post
    Which struts?
    Bye bye Vec B
    - Hello Siggy!
    Wales, UK
    Sorry, lol dampers and springs all ok?
    Birmingham
    I assume SPRING OK? Damper....no idea! Im pretty much going along common faults knows to all oweners!
    Bye bye Vec B
    - Hello Siggy!
  1. Knocking after oil change! Help please guys
    By Desolation91 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2013, 00:09
  2. common knocking noises on vectra c
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2010, 22:50
  3. Curing tailgate knocking noises
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 09:51
  4. Knocking noises - Help!
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2009, 09:19
  5. Suspension change - now a knocking noise
    Last Post: 5th November 2008, 21:12
