Results 1 to 2 of 2
Thread: ABS and Traction Light On Together
    May 2006
    Mansfield
    Default ABS and Traction Light On Together
    Apologies if this has been discussed before.
    After having a new clutch, noticed twice now that when I first start the car the Traction Control Light and ABS light come on together and stay on, turning ignition off and and on again clears them. Loose ABS sensor connection maybe, or has anyone experienced this and cured it.
    many thanks in advance
    SJ
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Oh dear, You are correct, it the abs sensor which is part of the hub.
    Changing the clutch and having to remove the driveshafts might have done the damage to an already poor hub.
    Check the connector from the sensor which is attached to the strut, hopefully it just needs cleaned or pushed together tighter.
    If both lights stay on all the time you'll probably need a trip to the stealers for a new hub. They do a non-genuine one for about £80 from memory.
  1. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  2. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  3. Traction light
    By viki_3.2 in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2009, 09:34
  4. Traction light
    By Monza30 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 23:37
  5. Traction/ESP light on in the wet
    By Daave in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2007, 16:05
