Results 1 to 10 of 14
Thread: Oil consumption 2.0 dti or oil leak
    dudley
    Default Oil consumption 2.0 dti or oil leak
    Just a quick question on oil consumption, I'm having to top up with 1 litre every 3-4 months cars covered 122k, fully serviced @120k, is this normal or do i have a leak, going to take the engine under shield off this weekend to have a look for suspect leaks, are there any common leaks that I should look for.cheers
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Injector seals, rocker cover gasket. Is your engine oily?
    dudley
    Quote Originally Posted by Celes View Post
    Not from looking at the top of the engine but the underside could be cleaner, haven't noticed any drips or spots of oil, just thought the bottom was dirty and grubby from 122k but need to have a better look, fuel filter wasn't oily on the last change so don't think its injector seals, although I haven't ruled them out as faulty, they will be a job for a sunny day, as its a pain to start when left up hill, on the flat or pointing down its fine for days, a little throttle on start up and its away.
    Just read about rear sump/oil gasket big job but is there anywhere else it could leak from like oil coolers or oil pipes.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Faulty injector seals won't cause the fuel filter to be oily. They do however cause starting problems if the car's nose points up.
    So you're saying the engine looks clean, from the side? Is the turbo in good condition?
    My V6 CDTi is bone dry at 167k miles
    Regular Member cameraman's Avatar
    Leicester
    How many miles in 3-4 months?, in my car that would be 10,000 miles so a litre would be acceptable. My fist Vec-C the 2.2 '03 plate used a litre every 3000 miles from new all the way to 122,000 when it was replaced
    West
    Quote Originally Posted by cameraman View Post
    According to the dealers, there's no problem as long as your doing 1000 miles or more per litre...
    my old 2.0 dti never used a drop between services
    Leicester
    My 1.9cdti didn't use oil either, just the 2.2 petrol but as you say it was within spec at a litre per 1000 miles. My mates 1.8 was using a litre a day at 130,000 miles, the leasing company took it off of him so they could sell it while it was still running
    dudley
    there must be a leak somewhere, as I don't cover many miles about 350-400 per month, its lost/used a litre since the end of November but having worked it out thats only 1200 miles...
    it doesn't smoke at all so assuming turbo is ok, took the engine under tray off today and there is evidence of a leak, although it all looks very sticky and not fresh and drippy which I would expect a leak to be like,
    I have a haynes so i think its time to get messy and clean it up to see if I can find the leak, any pointers to go after, oil pipes, oil cooler, common faults, any ideas...?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I know of a 3.0, well actually two but one's exploded lol, that had a huge oil leak near the crankshaft pully (spelling?). It was the crankshaft seal or something. One had a goo-ey deposit, not drippy and very sticky.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not to rub salt it you wounds but my 2.2dti has used about half a litre of oil in 9k or so. Even although if I remove the air inlet pipe at the turbo there is a small line of oil in the bottom of the pipe. I think that is normal though
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  3. How much oil consumption is too much?
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 19:38
  4. 3.2 consumption
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 20:17
  5. Oil consumption
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2008, 20:30
vectra problem oil usage 1 litre a day
vauxhall vectra has a slight oil leak on rocker cover 03 plate 2.2
vauxhal.signum oil leak 2.0cdti
opel 2.0 cdti oil leak
52 plate vauxhall vectra c 2.2 petrol rocker cover gasket change
astra 2.0 dti oil consumption
