Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: not pulling away good[loss of power]
    Regular Member Garfo's Avatar
    plymouth,devon
    Angry not pulling away good[loss of power]
    hi all
    my 1.9 cdti sri 06 vec is not pulling away good, it goes at walking pace then if u rev it a alot the turbo kicks in
    not funny when ya tring 2 pull out when busy
    have done some reading on here and some people have cleaned there valves and other bit that goes onto it.
    garage has done this for me today costing £117 now the prob is still there
    so if i replace the chip thing that goes onto the valve will that cure it?
    if so where can i buy it?
    help me this car is driving me mad
    plymouth,devon
    anyone?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    if there is lack of power below 2k rpm defo sounds like your EGR valve mate.
    If a good clean does not resolve then its time for a new one - sorry.
    plymouth,devon
    ok will try a new 1.is that all i should replace?
    EVERYWHERE
    Lack of power can also mean the dreaded 'swirl-valve' thing has reared its ugly head once again. I'm assuming that you have a 150 because the 120s don't have them?
    plymouth,devon
    yeah 150 m8
    whats that and where can i buy it?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Was going to say the same.
    Could be an inlet failure - and specifically the Swirl flaps..
    basically the inlet is divided in two sections and swirl or tumble flaps allow flow between the two.
    These flaps can clog up for one, and also very common the bar on top of the inlet falls off due to wear in the ball joints holding the bar on. There is a motor that operates the flaps, but it actually only operates the 3rd flap and the others open as they are connected via this same bar, when it falls off the flaps can operate different and some not open.
    You get up and down movement in the tumble flaps due to the bearings in the flaps wearing, this then causes up and down movement on the flaps (shouldnt happen) meaning gunk can get through etc, and this is probabily the cause of the top bar falling off as the up and down movement wears the ball joints.
    In short - the fix is a new Inlet manifold and operating solenoid (plus EGR is recommended)
    Hope that kind of helps - I have a pic that will show you where this is., one sec
    plymouth,devon
    ok many thxs
    Middlesex
    Trim : SRI
    Mileage : 100k
    Pics as per explanation above:
    Engine with new inlet:
    Closer of Inlet showing top bar that is prone to fall off:
    Closer again of inlet showing inlet bar close up
    And even closer showing how the bar attaches to the top of the swirl / tumble flaps:
    Hope this helps again
    Middlesex
    Trim : SRI
    Mileage : 100k
    Dont let all this put you off tho mate - could still only be an EGR thats the first point of call..
    And also a check to see if the rod has fallen off the inlet.. If its still in place I would defo go with the EGR... if the bar is lying on its side off the swirls - thats a different matter
    CHeers
  1. Pulling Power
    By Quirrel in forum Engine & Drivetrain
    Last Post: 22nd December 2011, 19:48
  2. No power pulling off when cold??
    By digitalinkjetman in forum Diesel Engine related
    Last Post: 11th December 2011, 12:45
  3. lack of pulling power
    By garvey in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 12:59
  4. Pulling Power - BP SUL - Tonight
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2007, 00:42
  5. more pulling power
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2006, 12:45
vectra c loss piwer when pulling off
