Thread: same wwird indicator problem
    edinburgh
    Default same wwird indicator problem
    car had left indicator on all the time nd bulb warning showing. changed sidelight bulbs and cleaned contacts but light wont go off and now sidelight not always working! any ideas or shall i torch the car?
    thanks all
    Graham
    You say that the side light isn't always working, thats why your indicator light is on. Check for a good 12v supply to the side light
    Nottinghamshire
    As above...
    It may be necessary to bend the connectors in the sidelight bulb socket a bit so they make firm contact with the bulb, as well as cleaning them. They may just not have sprung back enough to make proper contact with the new bulb after having been pushed back by the old bulb for years.
    Also try another new sidelight bulb in case the first new one was faulty itself, and check that you don't have any other lights out anywhere on the car.
    edinburgh
    Thanks. ill keep checking.
  1. Indicator problem when turning
    By gspott in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2012, 14:05
  2. indicator problem
    By jamie226 in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 08:01
  3. Strange Indicator Problem
    By Andrew-hobin in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 10:29
  4. Annoying Indicator Problem
    By laingyc in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2010, 13:59
  5. weird indicator problem
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 10:45
