Results 1 to 10 of 22
Thread: pulling to the left
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default pulling to the left
    since ive had my front driver side spring changed my cars been pulling to the left. i had new tyres last week which meant the wheels were balanced. i also went to kwik fit who said the tracking was spot on. but yet the car is still pulling to the left. any ideas guys?
    Cambridgeshire
    Quote Originally Posted by monty2000 View Post
    Did you replace both front springs or just the drivers side?
    Sep 2009
    swansea
    Trim : Club
    Quote Originally Posted by parsco View Post
    Just the drivers side
    Cambridgeshire
    There is your problem mate.
    If you've just replaced the drivers side spring it will be 'stiffer' than the passenger side which means that it will probably sit a little higher than the passenger side too. Thereby tilting the car to the left and making the car pull to the left slightly.
    Did you take it to a garage to get the spring replaced? They should know full well that they should be replaced in pairs
    Sep 2009
    swansea
    Trim : Club
    the dealer i bought my car from done it. it went in for a new dmf and ended up having a new spring. so i have to change the passenger side to?
    Full Member spennny's Avatar
    Blantyre
    Straight back round there mate and ask them to do the other side also
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No you don't need to replace in pairs, if it is in good, working condition. (*Expert opinion* the 'need' to replace springs in pairs is simply not true if the non failed one is in 'good condition')
    I will assume they fitted the correct spring, ie correct rate(s) and length for your car. I will also assume that the other one is in good condition, not been overloaded or cracked / broken or excessively corroded.
    Changing one spring should not cause the car to pull to the left, unless it was not done correctly
    How severe is the pull, as just about all UK cars pull slightly left - in case you fall asleep at the wheel the car goes into the verge and not the opposite carriageway.
    Sep 2009
    swansea
    Trim : Club
    its not too bad. i have to keep the wheel turned slighlty to the right to go straight
    Cambridgeshire
    I thought that springs tend to settle over time. And with the age of the car (5 years old or so) putting a brand new spring on one side would have an effect on the way it handles
    Sep 2009
    swansea
    Trim : Club
    saying that kwik fit did say leave it a couple of week to let everything settle then call back
  1. Pulling to the right, then left.. Help!
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:06
  2. Pulling to the left
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 21:52
  3. Pulling to Left
    By Diet1985 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2009, 20:39
  4. pulling to the left
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2009, 19:51
  5. Car pulling to left
    By andy1103 in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 22:52
vectra c pulling to the left
vectra c pulling from side to side
