Results 1 to 2 of 2
Thread: z18xe engine
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default z18xe engine
    hi all i was helping my friend out with a zafira 2002 1.8 engine with his engine managment light on about a year ago it came on and the garage changed both o2 sensors front and back of the cat the light went out but then came back on again and been on ever since i have now looked at the codes and there is one present all the time i forgot the code number but it says o2 heater circuit out of range i think
    any ideas will it need a new sensor again or not?
    Regular Member billyyoung's Avatar
    dundee
    just had a simliar problem with mine, fuel trim bank malfunction , heated o2 sensor malfunction got to the bottom of it , the maf sensor was not showing the air going through it . try and get it on a computer with live sensor data. that might help it will show you the voltage going to the o2 sensors but it is in milli volts . also check for resistance over the sensor to think the auto data book gives you a figure to check for
  1. z18xe engine swap
    By ste_goffy in forum Engine & Drivetrain
    Last Post: 16th January 2012, 00:55
  2. Cheap Z18XE Engine Spruce Up
    By Das in forum Quick Photo Album
    Last Post: 10th March 2011, 16:39
  3. Z18XE engine details
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 03:15
  4. Correct oil for Z18XE engine
    By Bobtroll in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:52
