Thread: Radiator leaking
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Radiator leaking
    Hi All,
    Just noticed that the drivers side edge of the radiator is damp, looks like there is a leak.
    Has anyone had any success with any of the rad weld products, or is it better to replace the rad. I’ve never used any of the sealing products, not sure if they can mess up the cooling system pipes/pump etc. or compromise the anti-freeze.
    Any idea how much a new 3.2 radiator is (not sure if any of the vecs have the same fit) – do you need to exchange old unit.
    Been an expensive day – had both front bottom steering arms (£137.25 each)- think these are also called the drop links and both rear shocks changed.
    Regular Member old cruiser's Avatar
    slough
    I wouldn't use radweld mate as it could block up some of the smaller water ways, would just bite the bullet and get new Rad'
    Cheers Pete
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    as pete says wouldnt wanna use radweld especially on your engine a new rad from vx is 173.3 plus vat part no is 13191386
    Quote Originally Posted by Swatty View Post
    Hi All,
    ha ha ha he said front bottom
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I used 'Bars Leaks' a long time ago to cure a very small leak. It has been fine ever since. Use as the usage guidelines. It hasn't blocked anything up in the system, except for the small leak of course.
    The coolant was changed after about 40,000 miles when I changed the waterpump. Not problems since.
    Jul 2006
    greenock
    Thanks for your help/feedback all.
    Think that the new unit looks like the best option - thanks for part No. and cost.
    Can you replace the radiator without removing the oil cooler unit?
  1. Leaking Radiator
    By neocaligatio in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd June 2012, 13:58
  2. leaking radiator
    By coooky in forum Engine & Drivetrain
    Last Post: 8th November 2011, 10:58
  3. radiator leaking
    By recoveryman in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 16:42
  4. Radiator Leaking! Help!
    Last Post: 7th January 2010, 23:18
  5. Radiator leaking from drain tap
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 30th March 2009, 19:53
