Results 1 to 10 of 11
Thread: 12v power suply for stereo
    Regular Member ssunder's Avatar
    Hampshire
    Default 12v power suply for stereo
    Can some one point me out where i can run a live 12v ignition power suply for my stereo so that when i turn the ignition on the stereo will power up to, on a vectra c 1.9cdti sri 55plate.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Take it from the cig-lighter.
    Hampshire
    Quote Originally Posted by kenp View Post
    Do i not need 2 12v power suply for the aftermarket head unit?
    Is there any way to get the stereo working the way the standard fit units do? (On and off with ignition and also being able to turn on when the key is out).
    Engine : 2.2 Direct
    Then you have to
    1 perm live from eg. the glovebox light
    1 ing live from eg the cig lighter..
    Then it should be okay.
    Hampshire
    ok, will try that tomorrow and see what happens, thanks
    Regular Member SRI Chris's Avatar
    Jul 2009
    uk
    hi i take it your removing the original and putting in an after market one ?
    if so why are you worried about getting switchable 12volts and permanant etc as there already there ? just cut and connect into the original loom job done or am i missing something ?
    from chris
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    SSunder has a 2005 full canbus radio...
    It will not have an ignition live on the radio.
    There is a permanent live though on pin 15 (red)
    Ignition live is usually taken from the Cig lighter connector - black wire.
    Personally, I don't think that there is a facility to have ignition logic on/off control in a non vauxhall OEM radio.
    Jul 2009
    uk
    Quote Originally Posted by Robsey View Post
    ahh right with ya now didnt know that aged model was canbus.
    i am new to the vectra c vehicle so not up to speed yet with the age/tech specs etc i know my 2008 sri is canbus but didnt know about older models sorry guys.
    from chris
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes for all newbies,
    Full Canbus started in October 2004 (54 plate)...the main difference being that before that date all stereos had ISO connectors with 36 pins and an ignition live.
    Radios have model codes CCR, CDR,NCDC and NCDR.
    After that date, the radios had a 40 pin Quadlock connector, and the canbus system controlled the ignition live, multi-timer controller and other radio functions including back lighting etc. Radios after that date have codes CC20, CD30, CDC40,CD50,CD70 Navi and DVD models.
    swansea
    I fitted a new Kenwood with no problems at all. '55 facelift, just used the steering control cables.
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. Stereo no power???
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 22:19
  3. My New Stereo Alpine Stereo....
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2008, 20:31
  4. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
  5. Stereo Power
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2006, 22:11
