Thread: Does anyone know??
    West Haddon, Northants
    Default Does anyone know??
    If a 2005 Vectra 1.8 16v will be capable of pulling a trailer with a small car on it? I plan to use a Corsa B as a track car but need to know if the car will be able to pull the weight without any issues?
    Any help is greatly appreciated
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    yeah should be fine as if its a track car then it will mostly be stripped out anyway
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    A 1.8 manual has a kerb weight of just under 1.4 tonnes, so as long as Corsa on trailer doesn't exceed about 1.3 tonnes (basic rule - towing veh heavier than towed veh) and the trailer is balanced so as not to exceed the towing veh max rear axle load, then you should be ok. Personally, I'd prefer a more powerful towing veh though.
    Also check your driving licence to see if you are permitted to tow and if there are any trailer weight restrictions - common on newer issued licences.
    Thanks for the advice, will have to work out all the weights just to be sure!
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    if 1986 is your year of birth you will have passed your test after 1997 so you will not have the entitlement B+E on you license (look on the bottom left of the card bit) so are limited to a trailer weighing no more than 750kg OR (and this is important) not to exceed 3500kg combination weight i.e. tow car + trailer + track car + everything else yourself and other passengers included tools parts etc so long as no design weights are exceeded
    hth
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it is any help,
    I once towed a 2 tonne Range Rover for about 3 miles with my lowly Cavalier 1.8 CFi 8v car.
    It pulled very well indeed, much to the surprise of the Range Rover owner
    I only did this as an emergency measure, but I am still using the car to this day with no ill effects to the clutch etc.
    Regular Member john-d's Avatar
    Nov 2009
    washington
    a lad i speak to on corsa sport uses a old vec gsi as a towcar, its obv a lot more powerful but he loves it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Check the maximum train weight on the B pillar of drivers door aperture
    Regular Member colalowe's Avatar
    in the North
    if i remember correctly the trailer has to have its own brakes if its more than 3/4 the weight of the towing vehicle as well.
