Results 1 to 10 of 11
Thread: Gearbox problems - Thoughts if poss
    Default Gearbox problems - Thoughts if poss
    Hi Guys
    Posted on Saturday that my clutch was on the way out, slippig and smelling quite bad.
    Driving car to the yard, got half way there and it wouldn't drive. Car in gear clutch released and it just revs. Also able to push car whilst in gear.
    Any ideas?
    Thanks in advance
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Hope you have some cash in your wallet matey, cant really be anything but a totally burned out clutch, unless there's a mechanical failure of something else which is keeping the plates from coming together (less likely) It's a garage job unless you can do the work yourself.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    It could be the slave cylinder that has been worn and needs to be changed. It is a cylinder that presses on the clutch and works by the brakefluid from the car.
    Can you see brake fluid running down on the ground from the gearbox??
    My money is on a new clutch
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    im with you big sig
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    New clutch by the sound of things dude....sorry (
    Quote Originally Posted by marktaylor View Post
    What she said
    oooopppss sorry sean
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Quote Originally Posted by Hummelshøj View Post
    Sorry but never will a slave cylinder cause problem described,the only way would be if the slave cylinder seized with the clutch released ie cover plate depressed,if it had leaked it would'nt have the pressure to stop the clutch returning to the engaged position.
    IMHO
    Cheers Ian
  1. gearbox problems 6 speed
    By Даниил in forum Engine & Drivetrain
    Last Post: 8th October 2011, 20:43
  2. vectra c 1.8 sxi whine from poss gearbox
    By psychosteve in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 22:43
  3. Gearbox problems???
    By TUX-VECTRA in forum Engine & Drivetrain
    Last Post: 22nd May 2007, 01:14
  4. 3.2 GSi Gearbox problems
    By Scooby in forum Engine & Drivetrain
    Last Post: 7th September 2005, 14:30
gearbox fault poss
