Thread: Rumbling
    Jan 2010
    confused Rumbling
    Hi Iím after a little help if pos.
    2.2 Petrol direct 2008, 6 speed.
    I have a Rumbling noise from the front end that sounds like the exhaust is vibrating on the under body, this only occurs when pulling away,
    I have had a good look around the car but all clearances seem fine, I have also considered it may be the DMF but no one seems to have had these symptoms i have had a good look around the site but no joy, any help would appreciated
    Jan 2010
    [quote=deathdisco;1191346]Hi Iím after a little help if pos.
    huh !
    Jan 2010
    £)*(&%$)+()*^&%^&$% Vauxhalls bag of Sxxt
    WGAF#5
    any possibility that the problem could be the internals of the catalytic convertor braking up ?
    best to try getting under the car when cold and hitting the exhaust components one by one - im sure you will find that something is either loose or touching or indeed broken
    Regular Member Grahamy's Avatar
    Ryton
    loose heat shield maybe
    Jan 2010
    Hi Guys thanks for yur tips had a good look under the car grabbing at everthing but all`s good so back to the dealer and it `s looking more like the Damn Mother Fxxker
    Oh well at least i`m not going mad
  1. rumbling noise
    By signum83 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 21:00
  2. rumbling
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2010, 21:48
  3. rumbling but only when accelerating
    By bookie49 in forum Engine & Drivetrain
    Last Post: 5th March 2010, 21:06
  4. rumbling over 3000rpm
    By rec in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 08:40
  5. Rumbling noise
    By Keyboard in forum Suspension, Wheels & Brakes
    Last Post: 5th November 2008, 20:29
