Results 1 to 10 of 14
Thread: changing o3 vectra steering whell help
    tyne and wear
    Default changing o3 vectra steering whell help
    ok noob needs help i just took off my steering wheel from the 03 sri and i want to put it in my 03 1.8ls thought would be the same conections but on the sri ther is one wire going into airbag and on the ls ther is 2 is it a case of unpluging and changing the wires aswell as the wheel?
    The air bags are different so you need to change the lot over to fit iirc.
    tyne and wear
    when u say all you mean wires and aswell wheel
    If its even possible - I cannot remember - then yes the wires and everything as I think the airbag is a different shape? If its not then just swap them out of the wheels.
    tyne and wear
    just tried getting the wire out but seems to be stuck. air bag is diff as it a 3 spoke im putting in and a 4 spoke coming out. would it be possible to just plug the one wire into the air bag and leave the other free? seems to be my only option but dont want a airbag fault on dash :/
    Its not worth the risk of not connecting it up correctly as it will probably show up a fault and/or fail to deploy or go off at a random point.
    tyne and wear
    anyone else have sugestions same here are the pictures first one is for sri 03 i want to put on showing it only has one slot for one cable, and the other is an example of whts in the 1.8 03.
    also in second picture i scribbled out the wire so to show wht the sri air bag wiring looks like with the one cable out
    Can we see the front of the second please mate? I'm sure the twin plugs came in on the full canbus cars which an 03 wouldn't have been. Need to see the front of it to confirm...
    tyne and wear
    lol yeah i nicked tht picture from here as it looked the same hald on il go get a few pictures and post up
    Quote Originally Posted by Penfold101 View Post
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Basically one is a single stage airbag and the second is a twin stage. Both are different in terms of design internally, and the cim unit,(steering column module) and more than likely the complete system, You will have to find the same as whats in yours they are not interchangable.
  1. changing steering column controls vectra c 2003
    By morgan1664 in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 15:15
  2. changing steering wheels
    By taffy bhoy in forum Styling
    Last Post: 8th October 2010, 12:25
  3. changing vectra C steering controls
    By tox in forum Engine & Drivetrain
    Last Post: 17th September 2010, 18:36
  4. Changing the steering wheel
    By ScottR in forum Engine & Drivetrain
    Last Post: 25th November 2009, 10:17
  5. changing steering wheel
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2008, 21:39
