Thread: Oil filter change on a 3.0 cdti
    Default Oil filter change on a 3.0 cdti
    just thinking about servicing the signum and got the car over the pit at work to have a look and saw that the oil filter housing has a drain plug in it and that its going to need a special tool to remover the housing cover
    just found one on the internet on the laser website
    http://www.lasertools.co.uk/item.aspx?cat=375&item=3892
    OMG £28 for a tool i will probably use twice at the most
    how annoying as the vw/porsche/audi etc oil filter cup tool is £6 in halfrauds !!!!!!
    Regular Member i5aces's Avatar
    andover
    i was going to do mine as i have done the air fuel and pollen filters this weekend, but need to use the pit at work to do the oil,
    i havnt even looked under there yet, and just assumed it would be some sort of socket.
    would a oil filter removal tool not get it off, not ideal but should work?
    tried that but couldnt get any leverage on it think im going to have to bite the bulllet and get one !!!!
    Full Member Big Sig's Avatar
    Out of interest how much would somewhere charge to change the oil and filter if you supplied all the parts?
    maybe cheaper than the part you need?
    Regular Member Jezzy's Avatar
    S.E
  1. oil and filter change cdti 150
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 11:22
  2. Oil filter change 1.9 cdti 150
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 09:39
  3. 3.0 V6 Cdti oil filter change
    By themarbleman in forum Engine & Drivetrain
    Last Post: 26th March 2011, 16:14
  4. oil& filter change 1.9 cdti (120) vectra est '05
    By bigsteve in forum Engine & Drivetrain
    Last Post: 8th October 2009, 05:36
  5. 3.0 cdti K & N Filter change
    By M&S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2006, 18:14
oil type 3.0 cdti
