Thread: Irmscher Side Skirt Fitting
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Default Irmscher Side Skirt Fitting
    I've done a search but can't seem to find any directions on how to actually fit the side skirts: it's for a facelift Signum. Looking at the new skirts it looks like there's some lugs along the bottom and something under the water seal in the doors.
    I can't for the life of me actually get the old ones off: tried to take what I guessed were lugs out and it just bent and started to break, so I tried starting with the water seal in the doors and that has a lot of resistance to being pulled away and I don't want to pull it too hard incase it's secured somehow that can be damaged by tugging at it.
    Am I just being too lighthanded, or is there a knack to this that I don't know about.
    Sep 2009
    Stratford-upon-Avon
    http://www.vectra-c.com/forum/showthread.php?t=27850
    Read the above, you have to pull the weatherseal away, start at the front and work towards the back, at the back there is a retaining clip, but you will see it when you get there...
    Before removing your skirts go to vx and buy some speed rivets as you wont be able to re-use the old ones as the middle drops into the sill - genius design!!
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    vx sell the rivets in two sizes mate.. small ones are 20p each the larger ones are about 30p each....
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    You need both if you're fitting the full kit, at least I did when I fitted my VXR sideskirts although the rivets came with them. The small ones are for the cutouts for the jacking points, and the larger ones attach the skirt to the car along the top of the sill and underneath. Job takes about 20 minutes per side if you know what you're doing, a bit longer on the first one possibly...
    I'm getting a quote for painting from picador, might see how much more it is for them to fit as well.
    Jun 2009
    South Coast
    6 Post(s)
    ooh thats gonna cost ya.. getting the main stealer to paint and fit them is probably the most expensive option..
    Quote Originally Posted by Caveman_nige View Post
    I'm gonna get quotes from everywhere I can find tomorrow I think but Picador are meant to be the best body shop in the area - they won some sort of award IIRC, and I should get 10% discount with my gold card and might try to wrangle a bit more.
    Found it funny when I rung them up said I wanted some irmy skirts painted and she said "what model of astra is that?".
    i think you're just trying to dissuade me so you can have the skirts for yourself!
    If they charge you more than 30 quid for fitting them mate tell them to forget it and I'll fit them for you for the cost of fuel to get down to you which is only about 20 squid. Shouldn't take more than an hour to do both sides as long as you have all the rivets for attaching them and the end plates to go on the rear...
  1. side skirt fitting clips?
    By DANNYGRAY in forum Bodywork & Interior
    Last Post: 21st July 2012, 17:10
  2. side skirt fitting clips?
    By DANNYGRAY in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 21:16
  3. Irmscher side skirt bracket?
    By John LE in forum Bodywork & Interior
    Last Post: 7th February 2011, 14:02
  4. Fitting a quad irmscher exhaust system and rear skirt
    By gar1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2007, 23:09
  5. Side Skirt Fitting
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2006, 19:53
vectra c side skirt fitting
Vectra side skirt retaining clips
corsa c sri skirt fitting
irmscher side skirts door seals
insignia vx line skirt fitting
corsa c side skirt installation
how to fit vauxhall vectra outer sill skirt
