Results 1 to 10 of 11
Thread: Poor Starting
    Motherwell Scotland
    Default Poor Starting
    I have 1.9 120bhp, 2006, had poor starting and was advised to change the glow plugs. Have done this with no effect on starting, dont get me wrong I start ok on the first try, but it feels like its struggling a bit rather than catching straight away. I am now thinking some sort of fuel problem, new filter or something. Anybody had similar starting problems? How did you sort it?
    Oct 2007
    estonia
    we have 2 zafira Z19DT 120 hp with starting problem. Whan the car has been standing for more that 2 hours then the engine starts after being cranked about 5-10 sec. Feels like the cilinders are firing up one at a time until the engine starts. We have found no trouble codes, cam timing is OK, cranshaft speed sensor has been replaced, glow plugs and glow plug control unit is OK. No solution yet
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    This seems to be a theme at the moment. Mine's at the stealers just now getting investigated... Although at least yours starts at all! Mine just turns and turns Really annoyin...
    Motherwell Scotland
    Yes, Thats the same as mine. A mate has suggested giving it a shot of Redex, so going to try that and then perhaps clean boost sensor and EGR. If still the same, a new fuel filter. Let us know how you get on.
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by st2malo View Post
    Update if it helps: -
    http://www.vectra-c.com/forum/showthread.php?t=103464
    Motherwell Scotland
    Your update could have nailed it. Timing ould be out and this would make sense. Look forward to hearing how you get on. I will contact stealers to get estimate on checking timing and belts.
    Jul 2009
    Perth, Scotland
    Hope it's helped mate. I also hope due to the odd nature of this issue it's something that will be covered on warranty, other than that, f*** knows how much it's gona rob me....
    Motherwell Scotland
    I contact the local stealers and they quote me £41 to do a diagnostic, they will contact me before any work is done. They will deduct the £41 from final bill if more work is required. I might go for this and see what they come up with.
    Jul 2009
    Perth, Scotland
    Thumbs down
    Seems fair... hope there's not too much to be done!!
    the only ace in the hole I have is the p*** poor service I've had so far! Lack of callbacks, being cut off, staff not knowing who each other are, not to mention whos car theyve got, what's up with it or who I even am... well that's gotta be worth a few quid off at least!!
    Motherwell Scotland
    I put Redex in the tank and filled up. It did start a bit better but the temp has not been as low in the mornings, so not convinced problem solved. Will strip out EGR and Boost Sensor and give a clean. If no better then I think the stealers are next.
  1. Poor Starting
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 23:55
  2. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  3. poor starting
    By kmx racer in forum Engine & Drivetrain
    Last Post: 26th July 2011, 22:51
  4. Poor starting
    By Croxley in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 20:25
  5. poor starting
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 12:14
