Thread: Egr manifold
    Jul 2009
    Leicester
    Default Egr manifold
    does anyone know if i can clean the complete manifold where the egr sits. I have cleaned the egr and the bit where the boost pipe is but can see that there is tonnes of crap where the egr actually wits, i will upload a pic later.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    is it a 2.0 dti,
    you can remove manifold for cleaning with the injector pipes uncoupled from the injectors,the manifold will just come out.
    i clean mine with brake cleaner,small scraper,small wire brush.be carefull with internal rod and flaps (don't force anything)
    when you restart engine you will probable have to bleed fuel injector pipes ,the dti is a pig to start when fuel system has been split.
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    i assume its the dti, and you are talking about this part
    i'm interested to know too, on how to disconnect the injector pipes and then how to bleed them on re-connection. mine is worse than the picture, do people still use GUNK???
    thanks
    atvb
    Michael
    please note, library picture
    Jul 2009
    Leicester
    yeah its the DTI im talking about, you saved me getting a picture.
  1. is it the manifold?
    Last Post: 15th June 2010, 16:09
  2. manifold help
    By Graeme01 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:20
  3. manifold help
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 31st January 2010, 22:20
  4. 2.4 manifold
    By lizard in forum Petrol Engine related
    Last Post: 15th November 2008, 22:00
  5. manifold will it??
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 21:28
